adjustable front/rear comber arm users-->
Old May 9, 2004 | 08:02 PM
myz8a4re's Avatar
myz8a4re
Default adjustable front/rear comber arm users-->
ok, im lowering my car with eibach springs & wanted to install some front/rear camber arms at the same time to get the right alignment afterwards. i dont do any autocross racing just some spirited street driving & was pretty set on the kinetix arms. in researching them i found that in some cases of adjusting the camber less negative after lowering screws with the toe adjustment geting into spec. has anyone dealt with this? will i be ok? i dont want to have to fabricate my lower rear arms in any way to get the correct adjustment. any input on this subject would be appreciated. i just want to have my car lowered, get the correct alignment specs(actually a hair less aggressive camber wise) & have good tire wear on my 19" tires........all input is appreciated!
thanx,
-justin
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
