255 front 265 rear on stock 18" ?
I can buy a set of 255/35/18 and 265/35/18 Pilot Sports Pretty cheap. Well the fronts fit? Or is it to wide? Will it rub? I know the rears will fit . My other option is nitto nt 555 245/40/18 front and 275/40/18 rears. Again this is on the stock 18's. Need some advice quick!!!
both your fronts and backs will fit... but they will not be the correct diameter
I would go with the Nittos...
even then, be wary that a 275 tire is not recommended for stock rim widths (minimum recommended rim size is 9")
Thanks Strife350z. I was thinking the same thing. I was reading last night an older magazine about 1g in a 350z they ran 275/40/18 front and back but it looks like you need a 30 offfset rim. I know the 275 is a bit wide for an 8" rim but discount tires says it will fit and they will warrantee it.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
