What cause steering wheel to vibrate
Old May 30, 2004 | 05:33 PM
krisG35's Avatar
krisG35
Default What cause steering wheel to vibrate
besides wheel balancing and alignment. Did both but still the steering wheel vibrates some on the freeway. I do have a leaking pass side shock... could that be it? I have TEIN springs all around on stock shocks.
Old May 30, 2004 | 06:19 PM
Strife350z's Avatar
Strife350z
do you have aftermarket wheels?
if so... do you have hub-rings?
Old May 31, 2004 | 02:46 PM
phoenixZ33's Avatar
phoenixZ33
Default Re: What cause steering wheel to vibrate
that couldn't help. fix that and see what happens. otherwise it's probably tire balance, and could be tire condition or alignment.
Old May 31, 2004 | 02:47 PM
Gurp's Avatar
Gurp
yup, im thinking hub centric rings as well...same thing happened with me with my old car...
Old May 31, 2004 | 03:30 PM
phoenixZ33's Avatar
phoenixZ33
could be the hubcentric rings as well..
Old May 31, 2004 | 11:01 PM
krisG35's Avatar
krisG35
nah, couldn't be. i know i had rings on my volks, and it also happens when running my stock 18s.
Old Jun 9, 2004 | 12:14 AM
bastard's Avatar
bastard
If your car is lowered, the toe is likely to be out causing a "slip-and-grip" kind of thing (this will feather tires eventually). Your tires could have a flat spot. The balance could be out. Something in the suspension or steering linkage could be loose. A wheel bearing might be messed up. The rim might be bent. The leaking shock might not control the wheel enough, resulting in a vibration. The hubcentric rings could be the wrong size. The road could just be bad.
I can't think of anything else offhand.
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
