10.5" Volk Gt-7 size ok?
Old Jun 7, 2004 | 12:39 PM
JasZ's Avatar
JasZ
Default 10.5" Volk Gt-7 size ok?
Well, my GT-7's are coming in next weekend, but it looks like my rears are going to be 10.5" instead of 9.5" due to a mix up. Is there any problem with running these wheels in the rear? My fronts are 8.5" wide.
Thanks,
JasZ
Old Jun 8, 2004 | 05:21 AM
350zSpeedRacer's Avatar
350zSpeedRacer
You'll have to roll your fenders to avoid any rubbing, but other than that you should be fine.
Old Jun 8, 2004 | 06:38 AM
JasZ's Avatar
JasZ
The guy at the shop thats doing it said they won't have to roll them since the rear wheels don't turn. Is that just bogus information? Has anyone tried wheels of that depth?
Old Jun 8, 2004 | 06:41 AM
350zSpeedRacer
Well, my 9.5s are a pretty tight fit in the rear, and just about every thread I've read with someone putting on 10.5s, they've had to roll their fenders. I suppose it also helps to know what width tire you're going with.
Old Jun 8, 2004 | 06:50 AM
JasZ's Avatar
JasZ
Cool. Thanks for the info. Is there any detriment to rolling fenders? I am going to have Dunlop tires 285/35.
Old Jun 8, 2004 | 08:45 AM
shaneotool's Avatar
shaneotool
What will the offset be? This will make the difference if they will fit or not.
Old Jun 9, 2004 | 07:41 PM
JasZ's Avatar
JasZ
I think the offset is 32
Old Jun 9, 2004 | 09:16 PM
apharmdb's Avatar
apharmdb
You'll probably be OK without rolling provided you do not lower your car. If you do you will almost certainly need to roll.
Old Jun 9, 2004 | 10:31 PM
JasZ's Avatar
JasZ
damn. I really wanted to lower it too. Is there some issue with rolling and cracking paint?
Old Jun 10, 2004 | 06:20 PM
apharmdb's Avatar
apharmdb
It is possible to crack the paint when rolling but an experienced body shop should be able to handle it. Though if you are really worried you can always have it trimmed with a cutting wheel. Also with a 32 offset (which I didn't read the first time through) you might still be OK with any modifications. I'd try it first just to see if you can get away with it but have your body shop waiting in the wings in case it does rub. Good luck and please post how things worked out for you. I don't think I've ever heard or 10.5 +32 so I'm really curious as to how things turn out.
sales@czp
Sep 23, 2019 03:30 PM
