wheels spacers or new wheels
I bought some adr msport 19x8.5 35mm offset. While the fronts look good the rears are inset to much. If I buy 2 rear rims 19x9.5 what offset should I go with and if I just buy spacers how big should they be? What would everyone suggest? Just rying to make it look decent.
Originally posted by maxipad96
The cheap spacers go inbetween your hub and your wheel. While the H&R spacers actually extend your wheel studs and are alot safer.
I was gonna go with a 25mm spacer because I wasnt sure what size to use. So 15mm will be ok even though its only a 8.5" wheel.
Whatsthe widest tire I can go? I was gonna put a 255/40/19.
i saw this @ performance nissan. the h&r spacers are 68$ and come with the longer wheel studs. they range in size from 5, 15, 20, 25 mm spacers.
http://www.performancenissanparts.co...roducts_id=385
OK, I'm in the same boat here... I am considering HP Design rims with +35 offset all around. I don't want my wheels to be tucked!!! PLEASE CORRECT ME IF I'M WRONG...seriously...I'm buying these rims today.
My rims would be 19's, 8.5f and 9.5r. According to this rim calculator ( http://www.mindspring.com/~toy4two/offset.html )
the new rims should stick out (8mil front and 17mil rear) beyond the stock 17's which have a 30f and 33r offset. The rest of the new rim will be in the well.
I don't want to buy spacers... 8mil and 17mil beyond stock is actually quite a bit if you think about it.
Zquicksilver
Alright, with everone giving different opinions, here is a summary of what I've read...
Front
19"x8.5" fronts, with 35mm offset (M-sport or similar)
Use a 15mm H&R spacer
Use a)245/35/19 or b)255/35/19 tires
Rear
19"x9.5" rears, with 35mm offset (M-sport or similar)
Use a)275/35/19 or b)285/35/19 tires
Now has anyone actually done this who can give opinions?
Front
Rear
I only have 19x8.5 all the way around but will be ordering spacers this week. Was gonna keep 235 or 245 up front and get a 255 in the back. Dont think I can go any wider than that since its only an 8.5" wheel. Also I though I would need either a 20mm or 25mm in the back since its only 8.5".
Front
Rear
Front
Rear
For the rear, I have 19x9.5 with a 35mm offset and a 15mm spacer and it fits perfect I think. Rear tires are 285/35/19. PM me if you want pictures.
