PILLOW BALL UPPER MOUNT question
Old Jun 29, 2004 | 10:24 AM
tranzholik's Avatar
tranzholik
Default PILLOW BALL UPPER MOUNT question
I have the Cusco Zero2's, when i got it in mail it did not came with the upper mount. Can someone explain the advantage of having the pillow ball upper mount over the fixed one. I know it improves the steering response...but how? that is my question...and is it noticeable on a track??
Thanks for any input!!!
Old Jun 29, 2004 | 03:38 PM
Resolute's Avatar
Resolute
A pillowball is just a hard steel spherical bearing. It allows a lot less deflection than stock, transmitting more of the road surface's irregularities to the driver. It is a very noticeable difference.
EDIT: spelling
Old Jun 29, 2004 | 08:36 PM
350Zteve's Avatar
350Zteve
Pillowballs are pretty much pointless on a double wishbone suspension like that of the Z. There is very little deflection on a DW setup. You also cannot change the camber by moving the shock on a DW setup.
On a MacPherson strut suspension, there is significant side loading since there is no upper control arm. Thus you see lots of guys running the pillowball/camber plate setup.
Old Jul 1, 2004 | 11:42 AM
RIVET's Avatar
RIVET
Not really, because your mounting the upper part of the strut to the car, as the suspension goes through its travel the strut pivots off the upper mount. A pllowball (hi-misalignment spherical bearing) compensates a bit better than a rubber hard mount so there is less side loading of the strut.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
