? 18" x 9.5" w/+45 offset on the front
Old Jul 7, 2004 | 05:47 AM
mpowers's Avatar
mpowers
Question ? 18" x 9.5" w/+45 offset on the front
Will a 18x9.5 with a +45 offset on the Z fit on the front? I have the wheels and I haves test fitted them with barley any room for the wheel to spin with out hitting the spindle. I have spacers comeing aswell, but I don't not want to scare a wheel while playing if they will not fit. The wheels are speedline corsa 2211.
Old Jul 7, 2004 | 05:51 AM
Audito350Z's Avatar
Audito350Z
you will need at least a 10mm spacer to get those to work, so I hope that is waht you have on the way... the spacer need to be hub-centric.... and once you do that, you will need the longer wheels studs... the wheel studs are something like $8.00 each...
Old Jul 7, 2004 | 06:10 AM
Gsedan35's Avatar
Gsedan35
I'm shocked that a 9.5" rim on a 45mm offset would not hit the control arm. Here's a pic from inside the fenderwell of a 18x8" rim on 45mm offset 245/40-18 tire and the clearence to the control arm.
I'd love to see a simular pic of your rim on the car.
https://my350z.com/forum/showthread....ghlight=hybrid
Old Jul 7, 2004 | 06:56 AM
mpowers's Avatar
mpowers
Yes I have nismo wheels studs comeing as well. The spacer I am not definite on what size it is, I had given them (company I puchased the wheels from) the distance of the spindle to wheel. This was by no means a garentee fit. If it works out I'll post pics.
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
