Am I reading these tire size right?
Old Jul 27, 2004 | 06:15 PM
Poison123's Avatar
Poison123
Google Bot
Default Am I reading these tire size right?
Can you put different sized tires on the stock Enthu 17inch rims? Basically instead of the 225/50's and 235/50's. Tirerack has some other decent tires just not in the exact sizes recommended for those wheels. I really dislike being limited so far to RE40's or the over priced Sports from them. So any ideas?
So could I for instance run 225/45/17's on the front, and 235/45/17's on the rear?
Old Jul 27, 2004 | 06:35 PM
westpak's Avatar
westpak
SFZCC
Yes but you will increase you wheel well to tire gap and look worse I think.
If you are going to go to 45 profile might as well go with wider tires and still keep the gap the same but get wider tire, like 245/45 and 255/45 don't know if they make tires in those sizes but they would be close to original dimensions other than width.
Old Jul 27, 2004 | 06:37 PM
roydiculous's Avatar
roydiculous
You can run those specs. A couple of things:
1. Your overall diameter is going to be less, your speedo is gonna have a tracking error. It's less than a 1% error (taken from 350zmotoring.com Wheel and Tire garage section)
2. Your car is going to be lower due to shorter sidewall/diameter
3. Your handling will be a bit different. I believe tighter response, less sidewall flex?
Good luck! And I hope someone can sound off on what I said. I'm definitely not an expert.
Old Jul 28, 2004 | 05:06 AM
Poison123's Avatar
Poison123
Google Bot
Bah screwit, I might as well buy new 18's or 19's. Seems the tire choices are better for those sizes anyway.
Old Jul 29, 2004 | 12:50 AM
MY350Z.COM's Avatar
Yeah get bigger wheels, those stock 17's gotta go.
Bigger wheels compliment the Z so much better.
Victor
burglapfd
Dec 6, 2020 01:04 PM
ablaine
Nov 29, 2016 10:13 AM
kyin
Oct 15, 2015 05:54 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
