tire wear question????
I put 275-40-18 tires on the rear....Kuhmo MX tires.... and I got a camber kit and changed the camber to -1.1 on both sides.... well my right tire is worn but on the outside.... thats seems kinda strange to me with the negative camber the left tire is fine.... does the right tire slip more durring a launch????? how can i fix this problem????? and i have only had the tires for 6,000 miles and I have not even been to the track yet????? I was thinking to put the camber settings back to 1.8 negative cause thats how it came from the facory but the reason that i set to 1.1 was because I was getting premature wear on the insides......any ideas????
I think you need to get your camber checked, maybe the bolts weren't tighten enough.
I have 255/35/19 and 295/35/19 I have 15k on these tires. I'm seeing a little wear on the inside but not much. I'm still running the stock camber setup.
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Tochigi_236
Sep 27, 2015 03:40 PM
