Biggest possible sidewall?
Old Aug 5, 2004 | 09:46 AM
Falcon's Avatar
Falcon
Default Biggest possible sidewall?
I am looking into getting a set of 19x8.5 Axis Milanos all around (eliminating the staggered set up) and wanted to get the biggest sidewall possible.
I was planning on running 245/35s all around, but I'm afraid that the sidewall might be too small... and I definitely don't want to be blowing out tires all the time (the roads can really suck around here).
Will 245/40s fit on the Z on 19x8.5" rims, or will I get fender rub?
Thanks in advance...
Old Aug 5, 2004 | 10:49 AM
ragtopz's Avatar
ragtopz
not an expert on the subject or anything, but being that you dont have vdc, it should be ok. i heard that non-staggered wheels with vdc may cause problems.
as far as the 245/40/19, that would be the correct size tire in the rear on a 8.5. (most run 275/35/19s on a 9.5 or 10.5)there shouldnt be any rub. the front, will be 1" larger overall, but shouldn't really be a problem.
someone correct me if i am wrong.
btw, welcome to the forum.
Old Aug 5, 2004 | 11:14 AM
Zquicksilver's Avatar
Zquicksilver
Zpilot on 350ZMotoring is running SP 9000s ( 245/40/19's) on a 8.5__+35offset rim and has no problems.
I'm actually considering 255/40/19's to match the diameter of 295/35/19's. I dont' want the jacked up 70's muscle car look to my Z because of side wall differences. Nice and even...
fongster
Aug 18, 2003 07:40 PM
zogan
May 19, 2003 10:53 AM
EmpiricalGMan
May 17, 2003 11:00 PM
denic79
Feb 13, 2003 09:37 PM
silverz
Jan 30, 2003 12:50 PM
