vdc question
Old Aug 17, 2004 | 03:27 PM
fresno350's Avatar
fresno350
Default vdc question
put 20" axis mods on my Z. i always turn off the vdc because im not sure if the new tires will mess with it. will these aftermarket rims/tires affect vdc readings?
Old Aug 17, 2004 | 04:09 PM
Rampant's Avatar
Rampant
It is the tires that make the difference--not the rims. What tires are you running?
Chances are, if you are running a wider rear tire than the front, with the same series (i.e. 35) you will be fine. You just need to have the rear tires taller than the fronts as the VDC was programmed to read wheels speed based upon the stock staggering.
Old Aug 17, 2004 | 04:13 PM
fresno350's Avatar
fresno350
i think the front is 35 series and the back is 30 series. 245/20 in front and 275/20 in back
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
