Help me decide
I'm getting 18"Volks next month. Not sure if I should get 8" front and 9" rear or 9"front and 10"rear. Also would like to know the best tire size for the set up. Your help would be greatly appreciated.
Originally posted by pharmboy
Get the 19's
Get the 19's
I would get the wider set up. The wheel wells are very large, they can easily accomodate 9's and 10's, some guys claim to be running 11's in the rear. Most are running 245 widths in the front and 275 out back. The trend seems to be to run 285's outback if you can fit them, depends on the offset of your wheels.
Well, I'll either get the 18" wider setup or go to 19". Is wheel damage a significant issue when you compare 18" vs 19"? Are there too many damaged 19" and intact 18"? While I get some replies I'll get the price quotes.
