Front Single Tire Replacement Question
Old Aug 19, 2004 | 10:07 AM
only1's Avatar
only1
Default Front Single Tire Replacement Question
I mentioned in another thread about replacing just one tire. I went and spoke with the Tire place and they said I did have a pro-rated warranty on the tire (pilot a/s), since I ran over a nail.
The question is whether to pay $100.00 for the new tire or should I buy two new tires? I am wondering about the performance since the other front tire has 7/32 tread left. The tires are pretty expensive, so I really don't want to buy two when I only need to replace one.
Any suggestions?
Will this increase the change of tire feathering?
Decrease performance?
Old Aug 19, 2004 | 11:16 PM
KY350's Avatar
KY350
Not sure if Michelin's have 10/32 or 8/32 on a new tyre. Either way, there is plenty of tread left and if I were you, i'd just buy 1 new tyre. Then try it and if I could notice a performance difference (ie car was unbalanced / skittish etc), then I'd buy the 2nd tyre.
Old Aug 20, 2004 | 07:24 AM
ChinaClipper's Avatar
ChinaClipper
OEM MIchelin tread depth is 10/32nds. Buy just one tire. You should be okay. If this were a rear tire, I would say buy two. The "stagger" between right and left tire diameters would put undue wear on the limited slip differential.
Old Aug 20, 2004 | 07:36 AM
only1's Avatar
only1
This will not cause tire feathering or abnormal wear will it?
Old Aug 21, 2004 | 08:15 AM
RedBird's Avatar
RedBird
You can't patch the tire?
Old Aug 22, 2004 | 07:54 PM
only1's Avatar
only1
nope, both bolts are on the side tread.
etkms
Jun 19, 2022 06:30 PM
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
Paul.
Oct 16, 2015 07:34 PM
sherm
Sep 10, 2015 11:02 PM
