Will a 275\35\20 fit?
Old Oct 20, 2004 | 04:21 AM
josephl30's Avatar
josephl30
Question Will a 275\35\20 fit?
What's up everyone!
I decided to go with the 20x10 in the rear and 19x8 front....and I wanted to get a much profile possible(side-wall protection). So, I was wondering if anyone is currently running this setup, or if anyone had any opinions on if I would have rubbing issues (NO VDC and I'm NOT lowering the car)?
Old Oct 20, 2004 | 06:10 AM
Strife350z's Avatar
Strife350z
rubbing will depend on your offsets... if you're running +25 to +35 with that setup (in the rear), you'll be fine
as for tires... I believe 275/30/20 (not 35) is the correct size, but if you're looking for more sidewall, they offer 285/30/20 as well
the 275/35 will work but your car's going to look like a truck (half inch taller off the ground) unless you're lowering
good luck
Old Oct 20, 2004 | 11:06 AM
t32gzz's Avatar
t32gzz
I have 275/35/20 tires on my rear and a drop via Tein Flex. They will work, and look fine. You will not rub at all, even with a drop, as long as the drop is less than 1.5"
Old Oct 20, 2004 | 11:59 PM
MY350Z.COM's Avatar
Default Re: Will a 275\35\20 fit?
Originally posted by josephl30
What's up everyone!
There are a few people running this size with their Axis wheels.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
