Tire PSI for winter Storing
Old Oct 21, 2004 | 06:37 PM
zand02max's Avatar
zand02max
Default Tire PSI for winter Storing
I have the Tracks, whats the highest I should go for PSI for winter storing?
I was thinking 40-45 PSI. Thoughts?
About to leave now for the gas station, so hurry with the responses, thanks, , Jeopardy music is playing,
Old Oct 21, 2004 | 06:45 PM
zand02max's Avatar
zand02max
First helpful answer gets my sandwich,
Old Oct 21, 2004 | 06:53 PM
MY350Z.COM's Avatar
Are they going to be stored while mounted on the Z or off the Z?
Old Oct 21, 2004 | 07:06 PM
MY350Z.COM's Avatar
Found an article on Google
In a perfect world, the wheels should be removed from the car and stored (see the next article). If possible, the suspension of the car should remain compressed to avoid the onset of rust on the shock absorber piston rods.
Should it be impossible for you to store the car without its tires, inflate them to 35 PSI (2.4 bar) or 40 PSI (2.75 bar), depending on the maximum pressure on the sidewall. Ideally, during the storage period, move the car for a few centimeters once a month or, if the tires are high performance tires, every two weeks to avoid the formation of flat spots.
If your tires are stored mounted on wheels, keep them inflated to a pressure of 15 PSI (1 bar).
Ideally, do not store them in an upright position, but stack them laying flat on their side. If this is impossible, leave them upright and rotate them about once a month to prevent the formation of a flat spot.
Protect them with plastic bags thick or dark enough to protect the tires from ambient light.
Avoid extreme temperatures and humidity. Above all, refrain from storing them outside, where they will likely be subjected to temperature swings and high humidity.
Do not leave them on a moist or greasy floor; isolate them with a wooden plank.
Keep them at least two meters away from electric motors and radiators. These devices generate ozone which oxidizes tire rubber and deteriorates the tires.
Old Oct 21, 2004 | 07:16 PM
zand02max's Avatar
zand02max
Thanks for the thorough answer.
BTW, I just got back, tires are inflated to 41 PSI. And they will be parked on carpet in my garage.
Tomorrow is the oil change, a wash, coat of Zaino, battery maintainer hookup, and then hybernation,
But I did save $321 by switching my car insurance to
Storage!
Old Oct 21, 2004 | 07:18 PM
MY350Z.COM's Avatar
What about gas stabilizer?
Old Oct 21, 2004 | 07:21 PM
zand02max's Avatar
zand02max
I heard bad things about that for the Z. Is it really necessary if I am starting it every two weeks and driving around the block for 10-15 min?
I have STABIL in my garage, but not sure if I want to try it. I normally reserve that for my lawnmower gas. Hmmmm.
Old Oct 24, 2004 | 11:14 PM
MY350Z.COM's Avatar
If you are starting it every 2 weeks then you'kll definitely be OK w/o the STABIL.
Victor
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
