Disable Tire pressure light
Old Oct 30, 2004 | 11:40 PM
Reefkpr's Avatar
Reefkpr
Default Disable Tire pressure light
Anyone know how to disable Low tire pressure warning light? I have added aftermarket wheels and I had the psi flashing on the combination gauge and a Low tire pressure warning light. I disconnected the TPMS receiver and fixed the flashing psi light but still get the warning light. Is there any way to disable or reset this warning light?
Old Oct 31, 2004 | 01:26 PM
Reefkpr's Avatar
Reefkpr
Well no replies from anyone so I am stuck. Today I tore the entire speedometer cluster apart to find a small led which is part of the mainboard. I put a small piece of electrical tape over the led and now no light. This is kind of a temporary fix and I sure wish someone could help. You Don't see any of the tape or anything but I really would rather disable it. Oh Well time to forget about the stupid light and start enjoying my new rims.
Old Oct 31, 2004 | 01:36 PM
jake280's Avatar
jake280
how did you disconnected the tpms receiver? and where is it found? i sure would like my psi light to stop flashing, right now its just covered with a sticker haha
Old Oct 31, 2004 | 01:48 PM
Reefkpr's Avatar
Reefkpr
It is behind the panel just above the passengers feet. If you crawl underneath and look back you will see the module located in the center of the panel. It has two connectors. You can reach up and disconnect the large connector, no need to remove any panels. No more flashing PSI. Also the Gauge will not default to the tire Pressure readout.
Uriyo_
Sep 8, 2021 08:46 AM
apex locator
Jul 23, 2021 02:27 AM
