Tires Sizes for stock 17" rims
Old Nov 8, 2004 | 12:38 PM
thor2822's Avatar
thor2822
Default Tires Sizes for stock 17" rims
What is the largest size tire than can be ran on the stock rims?
I was thinking about going 245's in the front & 255's in the rear.
Would you have to drop to a lower sidewall series with the larger size?
Old Nov 8, 2004 | 09:01 PM
Redline350Z's Avatar
Redline350Z
Yup, you can do a 245/45 in the front and 255/45 in the rear. That's wider than stock, but the same diameter so your speedo won't be off, and the traction control will be happy.
Old Nov 9, 2004 | 01:43 AM
Clyde's Avatar
Clyde
you can run 275/40 on rears and be ok
Old Nov 14, 2004 | 05:57 PM
raptorbh12's Avatar
raptorbh12
seriously? where can i find those tires? ive looked for a while but i cant find em. also ive seen that 275's need like a 9 inch wide rim to work, and the rear rims are 8 inches wide.
Old Nov 14, 2004 | 08:14 PM
roydiculous's Avatar
roydiculous
Don't go over 255 on the rear 8" rims. Whoever said 275 likes a bulging, unsafe tire.
Old Nov 16, 2004 | 04:16 PM
phoenixZ33's Avatar
phoenixZ33
The 275 setup is popular for autocross, but typically those tires are changed out every few months anyways and not driven on the street. I don't know if you'd have any problems using 275s on the stock wheels for street use, but I highly doubt you'd see any difference vs. a 255. Go with the 245/255 setup as someone mentioned. Do a search for 255/45-17 or 245/45-17 on Tirerack.com or tires.com and see what comes up.
burglapfd
Dec 6, 2020 01:04 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
kyin
Oct 15, 2015 05:54 AM
Li1ag
Sep 28, 2015 02:07 PM
