Help Needed!!
Old Nov 13, 2004 | 05:49 AM
frvargas35's Avatar
frvargas35
Default Help Needed!!
I just got a set of Volk GT-C rims...19's...mounted on my Z...they look pretty sick! The only problem is that around 100 miles per hour I get vibration from my wheels. Is this an alignment problem or do my wheels need to be balanced? HELP!
Old Nov 13, 2004 | 06:07 AM
roark's Avatar
roark
Sounds like a sloppy balance job to me. Swap them front to back (if possible) and run'er up again. If the vibration is gone or different, take them back for a rebalance.
Old Nov 13, 2004 | 06:17 AM
frvargas35's Avatar
frvargas35
I can't swap them...19 X 8.5 in front and 19 X 9.5 in the back...thanks for the advice
Old Nov 13, 2004 | 11:38 AM
Jun's Avatar
Jun
dejavu?
Old Nov 13, 2004 | 05:24 PM
biscotti's Avatar
biscotti
You should check to make sure that hub centering rings are installed on each wheel.
Old Nov 13, 2004 | 09:38 PM
twenzel's Avatar
twenzel
balancing problem or no hub-centric rings installed. easy fix. Just go to a reputable tire shop.
sherm
Apr 11, 2020 05:21 PM
