using a 20mm spacer dangerous for solo1 solo2?
I used spacers on my 240SX for three years in autocross and track events with no issues at all. I had bolt on type in the front, and long studs with slide on spacers in the rear... no problems with either at all.
Originally posted by del105
thanks guys, I bought some h&r 20mm spacers w/ 60mm hub bolts.
I also run the H&R 20mm spacers with the studs they provide (which I seem to remember are slightly longer than 60mm?) I know these where back ordered for a few months, could be they changed the studs they provide.
The knurled ends match the stock ones good, maybe a little shorter... haven't hand any problems with them for over 10,000 miles, they fit real tight. I usually change studs once a year if they don't break sooner, probably due for a change soon.
I bought nismo hub bolts, the 60mm variety.
I'm only using the 20mm spacers on the front. the H&R spacers came with bolts but I already had the nismo ones so the H&R bolts will be back up. They look to be the same size.
Subarism
East Canada
Sep 23, 2015 06:23 PM
FromGtoZ
Sep 20, 2015 03:41 PM
