Lug Nuts...
Old Nov 21, 2004 | 04:45 PM
Philthy's Avatar
Philthy
Boost Junkie
Default Lug Nuts...
Considering a set of lightweight alloy lug nuts, anyone have any input or suggestions?
Old Nov 21, 2004 | 07:51 PM
ChinaClipper's Avatar
ChinaClipper
I am running the Mutekis. They are the lightest I have found, with about almost a quarter of the weight of the OEM lug nuts. Beware that they are of a rather soft metal though, and wear off the corners without too much effort if you are careless or clumsy with the socket wrench. The open end design is also not recommended for winter use if your area sees a lot of water and corrosive salt!
Old Nov 22, 2004 | 05:32 AM
fasta's Avatar
fasta
Rays Engineering Performance Lug Nuts
Rays Engineering has a line of performance lug nuts made from Duraluminum. the lug nut are extremely strong and light (the Rays lug nuts are 0.8 oz. each compared to 2.1 oz. for the stock pieces).
The Rays lug nuts also feature one 7-sided nut per wheel. These heptagonal nuts look stock from a distance, but can only be removed with the specially designed socket that comes with the set. they are available in anodized red, blue, or black.
Old Nov 22, 2004 | 06:13 AM
del105's Avatar
del105
15 f125
dulalmin lugnuts are one of the best I've ever used. Same material as the Rays half the cost.
The don't specifically make them for the Z but they fit perfect.
http://www.subydude.com/parts/index....eelaccessories
Old Nov 23, 2004 | 03:01 AM
ttsupra94's Avatar
ttsupra94
Haha, nice lotus sig!
ttsupra94's Avatar
ttsupra94
I mean avatar
Old Nov 25, 2004 | 12:47 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
here you go...
available in blue black or red...
http://www.performancenissanparts.co...roducts_id=463
Old Nov 25, 2004 | 06:06 PM
Philthy's Avatar
Philthy
Boost Junkie
Thanks Jason... I already ordered them, Jeff took care of me.
Question, what's the recommended torque wrench setting with these?
Old Nov 25, 2004 | 07:46 PM
Jason@Performance
Performance Nissan
were you the one who emailed parts @ perfnissan about these on the track wheels?
torque spec, not sure I will check and post in this thread...
probably wont have something till monday...
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
