anyone seen this wheel in this size?
Old Mar 26, 2007 | 03:06 PM
ke0ki2k's Avatar
ke0ki2k
Default anyone seen this wheel in this size?
so i found some Enkei RPF1's in 18x10 + 38mm for sale on ebay by a company called Astig Racing. I havent seen this size anywhere before so I'm wondering if its a knock off or theyre just hard to find and this is the only place that can get em (they dont have them in stock, guy said it'll take 5 days to get em to their warehouse). anyone know?
Old Mar 26, 2007 | 04:17 PM
MR_X's Avatar
MR_X
I would either have them verify that they are 18x10 by showing them
the specs from Enkei. but 38mm offset is high though, you will need like 20mm spacers.
Old Mar 26, 2007 | 04:37 PM
ke0ki2k's Avatar
ke0ki2k
? i dont understand that...if the offset it already high why add spacers?
Old Mar 26, 2007 | 04:47 PM
MR_X's Avatar
MR_X
to bring them to an ideal offset. the Z benefit fro low offset. The lower the offset is the more is going to move outwards. factory wheels are 33. so if you go with 38 it will go farther inwards. you add a 20mm spacer it will make the wheel look like a 18 off set bring it closer to the fender making it look flush instead of sunken in. Understand?
Old Mar 26, 2007 | 05:06 PM
ke0ki2k's Avatar
ke0ki2k
k yeah now i got it, had to look it up on wikipedia. so would 18x10+22 with 265/35 fit up front no problem?
Old Mar 26, 2007 | 05:37 PM
MR_X's Avatar
MR_X
I should be pretty good
Old Mar 26, 2007 | 06:12 PM
twenzel's Avatar
twenzel
Yes, it will look quite good actually. Thats the exact spec of my rear wheels and put them on the front just to see if it would fit and it does.
Obadabot
Jun 18, 2023 11:31 PM
