Can Anyone tell me why this would/wouldnt work?
Old Jun 25, 2008 | 06:36 AM
ke0ki2k's Avatar
ke0ki2k
Default Can Anyone tell me why this would/wouldnt work?
Looking at a set of replica Mustang Cobra R wheels for my Z as a set of autox wheels for slicks. Theyre 17x10.5 +27 with a 5x114.3mm pattern. the centercap is 2.5 inches (63.5 mm) and it has 6.83" of backspacing. Theyre 150 bucks a piece with free shipping and theyre about perfect size & offset so I figured I would ask. thanks for any info!
Old Jun 25, 2008 | 07:35 AM
terrasmak's Avatar
Perfect for the rear , the front ?? But they do offer 17x9+25 for the front.
Old Jun 25, 2008 | 07:37 AM
phreaktor's Avatar
phreaktor
Design Engineer
pics?
Old Jun 25, 2008 | 07:40 AM
JSDZ33's Avatar
JSDZ33
in most cases you get what you pay for...
Old Jun 25, 2008 | 07:47 AM
JasonZ-YA's Avatar
JasonZ-YA
i think hes right... do the 10.5 in rear and 9 in front...
other than that, rock on!
-j
Old Jun 25, 2008 | 07:48 AM
JasonZ-YA's Avatar
JasonZ-YA
what year model R wheels are we talking about? im looking online for them and find different ones?
Old Jun 25, 2008 | 08:13 AM
MyV6IsFast3r's Avatar
MyV6IsFast3r
And they weigh probably close to 30 lbs.... Not a good autoX wheel at all... Find out the weight, if it's 25 or lower then I don't see why the 9" all around or 9f 10.5r wouldnt work... For AutoX wheel width isn't a huge deal IMO, weight is. Granted Im running 245/275 R comps now, but my next tires are going to be 285/295 so I want at least 9.5" all around but would prefer 10" all around width wise, and would like to stay at around 19-22 lbs.
Old Jun 25, 2008 | 08:18 AM
ke0ki2k's Avatar
ke0ki2k
http://www.wheelhq.com/mustang-black-cobra-17x105.html
my stock wheels weighed close to 25 pounds. My nismos were supposedly around 18 pounds but the fattern tires put the overall weight right back up to the same as stock. the race tires will be 4-5 pounds lighter than the street tires so the Cobra R's with Hoosiers will weigh about the same so weight is no real concern. I'm not looking for high quality, just cheap & wide. Planning on running a 315 out back and 275/285 up front to get a solid sidewall for turn in and feel. I'm just wondering if the back spacing or the center hub being smaller than whats needed will cause a problem as the wheel will not be "hub-centric"...not sure if that will cause a problem as speeds will never approach triple digits.
Old Jun 25, 2008 | 09:14 AM
terrasmak's Avatar
I8ACOBRA runs his slicks on those, they fit fine.
Old Jun 25, 2008 | 09:47 AM
ke0ki2k's Avatar
ke0ki2k
runs em on his Z? 17x10.5 all the way around?
Old Jun 25, 2008 | 09:50 AM
Spork's Avatar
Spork
10.5 all around would not be good.
I'm not even sure the front has room for a 10.5. It'd either hit the fender or the springs.
Old Jun 25, 2008 | 11:09 AM
terrasmak's Avatar
Just in the rear for his drag slicks, and yes , on his Z.
Old Jun 25, 2008 | 12:44 PM
ke0ki2k's Avatar
ke0ki2k
There have been tons of guys run 18x10.5's all the way around on Z's...stands a reason that a 17x10.5 wont fit lemme know. with a plus 27 offset it should be fine, might need a 5mm spacer. the tires would be the problem and my 275/35-18's dont touch.
I'm just wondering if anyone has run these up front and encountered any problems that ya just cant fix.
_bit
Oct 2, 2015 07:49 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
