Wheels Tires Wheels, Tires
FS: (4) - 15mm Hub Centeric Spacers and Studs
Old Oct 11, 2011 | 06:35 PM
ronn1's Avatar
ronn1
Default (4) - 15mm Hub Centric Spacers and Studs
SOLD
These are identical to Ichiba V2 set up. They are HIGH QUALITY billet aluminum hub centric with all hardware. I used them for 3 weeks, then got new wheels so there is no need now. I got them off ebay, but this is a highly regarded seller and quality is equal to or better than Ischibas. I had absolutely no problem installing these.
Here is actual Vendor info:
Product Description:
Brand New T-6061 HubCentric Wheel Spacers
Price For 2pcs (1 Pair)
Wheel Spacers are made from Aluminum/Magnesium alloy.
They are incredibly strong and very lightweight.
These are hub centric spacers that are specifically made to each vehicle.
Will fit on your vehicle's original hub perfectly without any gap.
Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center.
This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
Remember, this is not regular universal wheel spacers. These are all hub centric!
Make sure you check the spacer size and look at each important photo below before you making purchase.
We have extremely high experience of wheel spacers and extremely good customer feedbacks.
Check out our feedbacks and see how good the customer loved them!
Studs are already pressed, so plug and play!
You don't have to change any studs; it's way easier!
Spec Info:
Bolt Pattern: 5x114.3
Center Bore: 66.1MM
Thread: 12x1.25
Spacer Size: 15MM
Application: NISSAN 350Z
I have included a 17mm thin wall socket and 10 extra 17mm hex head lug nuts of very high quality (Gorilla). I started to round off a couple (2 or 3) of the kits lug nuts due to using a mulitipoint socket instead of this new 6pt socket (included) which won't do that.
$90 shipped for the set of four with all extra hardware included.
Offers accepted.
Old Oct 14, 2011 | 10:54 AM
ronn1's Avatar
ronn1
Bump..now accepting offers as well.
Old Oct 14, 2011 | 01:30 PM
350ZPK's Avatar
350ZPK
Interested. Any pics
Old Oct 14, 2011 | 02:58 PM
ronn1's Avatar
ronn1
Care to elaborate???
Old Oct 15, 2011 | 04:34 AM
350ZPK's Avatar
350ZPK
Huh
Old Oct 15, 2011 | 08:10 AM
Tko's Avatar
Tko
you have a pm.
EnjukuRacing
Sep 30, 2015 06:55 AM
