Sponsored by:
Sponsored by:
03-06/07-08 y pipe
Old 10-16-2014, 09:31 PM
alannc24
alannc24's Avatar
Default 03-06/07-08 y pipe
Ordering my Agency Power single exhaust today, but the Y pipe from my stock exhaust was welded . Needing to order a new Y pipe, but not sure of compatibility. From what I can tell from the pictures, the Y pipes were changed(and so were the under bodies??) from 03-06 to 07-08. I drive a 2007, and am not sure if an older model Y pipe would fit my car.
I've done my research, and have been browsing around for hours and have not found anyone with the same question as me
If anyone could help me out a bit it'd be great!
Old 10-17-2014, 03:04 AM
craig12895
craig12895's Avatar
Im not exactly understanding the question.
If you are asking if an 03-06 y-pipe will fit your 07, the answer is yes. But you probable shouldn't do that because the HR y-pipes are known to be much better for flow than the old y-pipes
Old 10-18-2014, 01:29 AM
calibredz33
calibredz33's Avatar
you didn't ask a question... but I think I understand the struggle... it isn't that hard.
either you, your friend, or some one you don't know(exhaust shop) are going to have to "mock" up where the exhaust will sit. then(if you don't want it welded) cut the stock exhaust off where it's to be mounted, add an exhaust flange(i think a 3" 2 bolt) to the now back of the y-pipe, and then bolt up the exhaust like normal after that. good luck.
sales@czp
09-23-2019 03:30 PM
Sleeper_Z
09-30-2015 10:25 AM
codek
09-28-2015 03:03 AM
Quick Reply: 03-06/07-08 y pipe
