370Z Wheels & Tires 370Z Rims and treads
opinions for 370 Nismo wheel spacers
Old 01-30-2012, 11:58 AM
zerosec
zerosec's Avatar
Arrow opinions for 370 Nismo wheel spacers
Hey guys,
was looking at my nismo today in the parking lot , and mmmm looks like the car needs front and rear wheel spacers !
any recommendation ? i know its comes with a pretty nice offset out of the factory but im looking for a more aggressive offset.
i was thinking of : 15 mm front and 15 mm at the rear....
what do u say ?
Old 01-30-2012, 01:03 PM
How far do you want to move the tires? 10mm? 20mm? 30mm? See how easy that was.
Old 01-30-2012, 01:10 PM
KingBaby
Hardest Setting
KingBaby's Avatar
I think from raping and plundering the37OZ.com site that 20/25 is the max without running into rubbing issues!
Old 01-30-2012, 05:39 PM
Goble
Goble's Avatar
If you want to go flush what I did was hang a Plumbob from the center of the fender. I then measured the distance from the center/fatest part of the tire to the Plumbob string and presto! That was how big of a spacer I needed to be flush with the fender.
Old 01-30-2012, 09:28 PM
Wait a minute you did this yourself? This practice of members measuring the distance between tire and fender has got to stop!
Old 02-01-2012, 03:02 PM
zerosec
zerosec's Avatar
well im looking for a more aggressive fitment while avoiding rubbing issues...
so i don't want to go with 15mm spacers at the rear if i can run 20 mm ones without facing any problems ....
no one is using spacers on their Nismo 370z ?
Old 02-29-2012, 04:04 PM
Italianjoe1
Italianjoe1's Avatar
Originally Posted by rodhotter
unless you go to big $$$ custom built wheels spacers are the way, looks better and can help handling, they add little weight a concern with bigger wheels!!!
Def not gonna help handling...
Old 02-29-2012, 07:12 PM
terrasmak's Avatar
Received 2,284 Likes on 1,646 Posts
Did you figure out to ask in the 370Z section, most of use are driving 350Z's that post in the "350Z wheel & tire" section.
Old 02-29-2012, 09:08 PM
Waiz
Waiz's Avatar
Silver wheels are 15mm spacers all around, the black wheels are without spacers:
Not a huge difference but it does look pretty good either way
Old 03-06-2012, 05:13 AM
SalmanZ
SalmanZ's Avatar
Those Nismo wheels look good in black...
Old 03-10-2012, 10:25 AM
medic165
medic165's Avatar
Hey guys,
any recommendation ? what do u say ?
I'd say buy the car 1st
Old 04-26-2012, 02:24 PM
zerosec
zerosec's Avatar
^ who said i didn't ?
Waizz thanks for the pics man, looks like im going with 20mm all around !
i'm also considering painting the wheels in black...
Old 04-26-2012, 02:30 PM
jg021v
jg021v's Avatar
Default 30MM atleast
30mm atleast because that gives clearance on the wheel studs!
Once the bolts are torqued, they are going to be around fourty nuts!
No rubbing with 18s on the 350Z.
30mm, gopher two.
Old 04-26-2012, 02:32 PM
Waiz
Waiz's Avatar
You're welcome!
This is my buddy Kyle's new setup, Matte black/white stripe and 20mm all around:
Old 05-02-2012, 03:31 PM
zerosec
zerosec's Avatar
likee !!
