350Z How to's
Old 09-26-2003, 01:41 PM
HokieZ
HokieZ's Avatar
How about an amp install howto (or link to one previously done). I desperately want to change the stock head unit and factory speakers but know it will require the installation of an amp which I've never done.
Thanks,
Old 11-09-2003, 11:22 PM
FairladyZ
FairladyZ's Avatar
How to remove the front bumper?
Old 11-10-2003, 12:41 AM
alphared
alphared's Avatar
Thanks,
Theres really no set way, you just find a spot and mount it. There are plenty of Amp installs (check the sub thread) Most install are either in the glove box or sub area (same thing just mirror each other.) The only thing really that you need to know is the Amp itself (ie, connections, number of amps, etc..) If you go to JL audio's site, they have info on how to hook up mulitple amps. Also you want to make sure your power and input audio are seperated. If not you'll get noise. IE. if you have power cable going to the glove box on the left and rca cables on the right. Don't mount you amp with the power input on the right and rca input on the left (hence crossing power over rca).
Old 11-10-2003, 12:52 AM
alphared
alphared's Avatar
wrong forum
Its under the Body/Exterior/Interior/Lighting section
https://my350z.com/forum/showthread....bumper+removal
Old 11-10-2003, 06:15 AM
FairladyZ
FairladyZ's Avatar
thanks!!!
Old 11-10-2003, 09:40 AM
corsair
corsair's Avatar
anyone know how to remove the weight in the trunk. i've done countless searches but turned up nothing.
corsair
corsair's Avatar
that is the weight in the hatch which prevents the trunk from fully opening.
Old 11-21-2003, 06:15 AM
srmd22
srmd22's Avatar
question: If you wire a detector into the homelink, will it power on and off with the car? And do you need any additional connections to the fusebox?
Old 11-21-2003, 06:53 AM
Rahtok
Rahtok's Avatar
Stealth V1 install: see link in my sig.
Old 11-24-2003, 02:04 PM
George350Z
George350Z's Avatar
Lightbulb Better Front Speaker Install
This method came to us as we installed the speakers, we had to mutillate the old speakers but so what.
Thanks for the help getting the door panels and rear speaker panel off.
Old 11-25-2003, 11:23 AM
theZman
theZman's Avatar
the "how to take apart the dash" link is not working. scafremon, did you move your website?
Old 11-28-2003, 02:33 PM
George350Z
George350Z's Avatar
Hey Zman,
This is where I found it, and I just checked and it was still there
enjoy!
George350Z
Old 11-28-2003, 02:34 PM
George350Z
George350Z's Avatar
Sorry, Here is the link,
http://liljerk.morpheus.net/350Z/
George350Z
Old 12-16-2003, 01:14 PM
TIGHT-Z
TIGHT-Z's Avatar
Default How about how to hook up 7" screen and DVD with wires? Anyone?
Old 01-25-2004, 09:51 AM
jaw4n
jaw4n's Avatar
Found this in an old thread for reference.
http://www.paragonwest.com:8080/350zmods/typerinstall/
Old 03-24-2004, 01:35 PM
Maxpowers004
Maxpowers004's Avatar
what do you have to do to the factory nav to get it to program while driving
Old 03-29-2004, 07:54 AM
pearl430
pearl430's Avatar
what about HOw to take the tweeter off???
anyone knows???
Old 05-01-2004, 08:19 PM
  #38
Infern0
Infern0's Avatar
How to change out door speakers? And what size will fit?
Old 05-02-2004, 01:39 PM
  #39
FLdrifter
FLdrifter's Avatar
Default How do I remove dash with stock Nav
I have the stock nav unit and I am not sure how to remove the dash. ( ie real question is what about the screws that are under the rubber mat in the pocket with no nav)?
Thanks
Old 05-02-2004, 05:25 PM
  #40
sparky3Z
sparky3Z's Avatar
Default Re: How do I remove dash with stock Nav
Thanks
I was helped greatly by a previous and well done post by Scafremon detailing the steps to remove the central dash and console. It was originally posted on another Z site but it appears it is no longer available at its original link. As luck would have it, I had saved the steps as an Adobe Acrobat file. Note that this was for the 2003 Z dash.
Assuming Scafremon will not object, I have placed a copy of the Acrobat file here for downloading:
http://lr-design.com/photos/%202003Z_Dash_Removal.pdf
The use of a magnetized screwdriver will help.
Quick Reply: 350Z How to's
