Help with system setup
Old Sep 7, 2006 | 05:14 PM
Tsyle's Avatar
Tsyle
Default Help with system setup
Ok this is what i'm thinking of going with
Amps:
Alpine MRP-F450 for speakers
Alpine MRP-M650 for subs
Speakers:
Alpine SPS-171A
Subs:
2 Alpine SWS-1042D
2 Alpine SWS-1022D
(what's the difference between the two? once says 4 and 2 ohm?)
http://www.alpine-usa.com/en/product...p?category=SUB take a look
Enclosure:
Zenclousre
HeadUnit:
not sure if i want to change this yet
Future:
carputer
i don't really listen to music that loud... and i only drive the car on weekends so i don't want to put an expensive system in. Just something better then stock... which is pretty much.. ANYTHING...
What you guys think?
Old Sep 7, 2006 | 05:56 PM
LayinLo's Avatar
LayinLo
Here, hope this helps:
DVC FAQ by JL Audio
Basically, the different amount of ohms lets you optimize the power from your amp to get the most outta your amp and subs.
I would recommend running a 4 ohm mono load, as this will be closest to your subs rms power handling capacity. Keep in mind, the Type S is only rated to 300 watts rms and the MRP650 puts out 400 watts rms @ 4 ohm and 600 watts rms @ 2 ohms.
To achieve this, you can run two 4 ohm (SWS-1042D) in a series/parallel configuration. The voice coils need to be wired in series and the drivers need to be wired in parallel.
Old Sep 8, 2006 | 07:49 PM
MUZZY's Avatar
MUZZY
definetly run 4ohms please
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
