DIY How to on Relocating your Cruise Control.
Old 07-27-2011, 05:40 AM
  #41
nosurf2day
nosurf2day's Avatar
yes you are correct 2 resistors, i dont have any in yet, i need to get some, I have the airbag light flash at me as well as my seat belt light. I need resistors for that too. My DIN looks like a christmas tree since I have the F-CON installed. No ABS, or Traction Control either. I say F it. And dont worry about it to be quite honest.
Old 02-01-2012, 11:46 AM
  #42
bmccann101
bmccann101's Avatar
bump..
nosurftoday.. is that other green wire coming off that bunch *( in the pictures) for your horn wire ground? Just curious as i have to fix that too.. unsure if thats the spot to find it.. im hella tall, its really hard to see stuff under that column.
Old 03-07-2012, 06:26 AM
  #43
zach711f
zach711f's Avatar
i wonder if you will still be able to switch maps with uprev osiris by doing this? there are more metal prongs in the connector where your cruise controls plug into. rather than splice into the two main wires for just cruise control. switching maps might not work.
Old 03-07-2012, 06:34 AM
  #44
nosurf2day
nosurf2day's Avatar
bump..
I am unable to see the pics from my military computer here in Afghanistan. I honestly cant tell you at this time.
As far as the maps thing, I dont believe I had that option in my car so I cant tell you.
My crusie control only managed my cruise and nothing else. I didn't have any other options on my 04 Z steering wheel.
Old 03-07-2012, 06:42 AM
  #45
bmccann101
bmccann101's Avatar
I have osiris going in.. ill repost and advise then..
Old 03-07-2012, 06:20 PM
  #46
zach711f
zach711f's Avatar
never mind..i just relocated my controls. there is only 3 wires in the harness that plugs into the steering wheel. the other metal prongs in the connector do not have wires connected to them. switching maps should work still
Old 03-14-2012, 05:08 AM
  #47
NZMOWND
NZMOWND's Avatar
bout to do this...i kinda like the in the headline suggestion! Thanks for the write up
Old 03-14-2012, 07:26 AM
  #48
nosurf2day
nosurf2day's Avatar
Glad that my write-up has helped so many people out. Never thought I would be the initiator of any posts that are highly sought out.
Hope you enjoy the pleasures of cruise control again soon.
Old 03-14-2012, 08:33 AM
  #49
JaE35z
JaE35z's Avatar
Can you fix the pictures?...nvm i see them on second page
Old 03-25-2012, 12:16 PM
  #50
NZMOWND
NZMOWND's Avatar
sooo what about if we have steering wheel contgrols for the radio...my plug has like 8 wires and not 3 and idk why but they arent the same color wires from the wheel to this plug...lost as hell!!!
Old 03-26-2012, 04:22 AM
  #51
NZMOWND
NZMOWND's Avatar
i finally found a pic with the wiring diagram and got my cruise relocated!! personally love that it is out of the way so i dont have to worry about my long legs accidentally bumping it. Plus, i feel like a jet pilot when i turn it on now!!
Attached Thumbnails DIY How to on Relocating your Cruise Control.-img_1686-1-.jpg
Old 04-22-2012, 02:20 PM
  #52
nosurf2day
nosurf2day's Avatar
that looks really clean! I like it.
Old 09-10-2012, 05:46 PM
  #53
truetaylor
truetaylor's Avatar
Did you ever get this to work? We are looking to make our uprev tune work in this manner as well.. We need to be able to switch for a NOS tune sometimes...
Old 10-06-2012, 02:46 PM
  #54
Azzerare
Azzerare's Avatar
thats amazing. If I ever spring for an aftermarket steering wheel, that's exactly where mine will be going
Old 10-10-2012, 11:41 AM
  #55
Nismo350z#0310
Nismo350z#0310's Avatar
Subscribed. Sweet this is exactly what I'm planning on doing. Thank you for this.
Old 07-07-2013, 10:06 AM
  #56
SIR_pierre
SIR_pierre's Avatar
JUST the thread i needed.. But the pics doesnt work =(
Old 07-07-2013, 10:09 AM
  #57
bmccann101
bmccann101's Avatar
There's literally no way to mess it up.. the exact same color wires as the cruise switch are on the plug on the back underside of the column combination switch..
Cut back some of the plastic sheath covering it..there's only two plugs..
Just dig in.. its very apparent and explanatory...not at all like digging for wires in the kick panel etc.
Old 10-20-2013, 11:20 AM
  #58
SIR_pierre
SIR_pierre's Avatar
Ive messed up..
I try to relocate my cruise-control.
And i plugged it on to the black and red cables that i found under the steering wheel.
I assumed that was correct since the colors inside the steeringwheel was the same.
And there, The black and red goes to the cruise control.
But that didnt get the cruise control to work.
And now the cas is F***up!
EVery light in the panel is on all the time.. ESP, ABS, Handbrake etc etc. and the engine dies while im driving!
What does these two blanc and red cables go to!?
What have i probably shortfused?
Old 12-03-2013, 11:08 PM
  #59
midz350
midz350's Avatar
From the 07-08 FSM: ( Cruise Control and Horn wirings)
B = Black
W = White
R=Red
G = Green
L=Blue
Y = Yellow
LG = Light Green
BR = Brown B
ORorO=Orange
P=Pink
PU or V (Violet) = Purple
GYorGR=Gray C
SB = Sky Blue
CH = Dark Brown
DG = Dark Green
I'm going to try this and report back here.
Attached Thumbnails DIY How to on Relocating your Cruise Control.-steering-switch.jpg   DIY How to on Relocating your Cruise Control.-horn.jpg
Old 12-11-2013, 07:46 PM
  #60
Neeko94
Neeko94's Avatar
Who on here can I talk to about this???
I have ALOT of question that might seem pretty dumb to alot of people but want to get it done
Quick Reply: DIY How to on Relocating your Cruise Control.
