HOW TO: Rotate Staggered Directional Tires...
Old 08-13-2007, 09:00 AM
  #41
FairladyZX
FairladyZX's Avatar
i just had my rear tires reverse mounted due to negative camber...hope they will last for a while...but dam the inside is all bald and ****......
thanks op!
Old 09-18-2007, 10:55 AM
  #42
meaj82
meaj82's Avatar
? for Op or anyone else that might know. I recently put on the OEM 19" g35 wheels. I had them rebalanced due to one guy that did it wrong. When the master tech saw the front tires(came w/ the wheels used) he noticed high-low spots on the inside part of my tires.
Will this cause excessive shaking(steering wheel) at speeds of 65mph+? Also if thats the case will this method of rotation help at all? I'm thinking I could have radial pull on one of the tires as well. My car pulls to the right now ever since I had them put on.
Old 10-07-2007, 08:17 PM
  #43
Desimale
Desimale's Avatar
Wow thanks for this thread I rotated my tires with my friend and looks like we did it totally wrong and now my tires are all uneven at 18k.
Old 10-07-2007, 08:41 PM
  #44
CEO350Z
That's bad juju
CEO350Z's Avatar
wow, just took a look at the original post date!
Old 08-01-2008, 07:30 AM
  #45
DoctaC
DoctaC's Avatar
So is this something everyone does? Is it universally accepted as 'worth it'?
I definitely understand the concept... I just would feel more willing if I had a buddy or something with a shop.
Old 10-19-2008, 08:36 AM
  #46
sry110
sry110's Avatar
So if I was to flip all of my tires meaning that the bald edge was on the outside, what happens when I throw my car really hard into a corner? Seems like I would have less traction than usual? I am thinking that I would rather install camber kit and toe bolts to get better tire life, and not screw around with flipping the tires around every 10k miles. Plus it makes my butthole pucker up whenever one of these shops has to touch my expensive wheels. I don't even let the stealership check my tire pressure anymore because once they did that and left scratches on the wheel lips under each valve stem. So the less times tires need to be manipulated on the wheels, the better.
Old 05-29-2010, 12:31 AM
  #47
xthejokerx
xthejokerx's Avatar
So basically this is like remounting tires... Should cost just a tad more than the normal $$ to balance and mount tires since there is an extra step of dismounting the tires.
Old 06-16-2010, 09:51 AM
  #48
sir_vq
sir_vq's Avatar
Originally Posted by dchi_t
my tires are bald on the inside due to tire feathering, if i do this rotate, am i still risking a tire pop on the freeway? because the bald side will be on the outside afterwards. just wondering, thanks
there a tsb-bulli for this feathering on the 'z' i think nissan will align for free look into it
Old 07-11-2010, 01:06 AM
  #49
S12 driver
S12 driver's Avatar
How much more tire life are people getting out of their tires by doing this though? If it's close to 10k miles I would say it's worth it, but if it's 3-4k miles, is it worth the cost to mount and rebalance?
sales@czp
09-23-2019 03:30 PM
Tonyz_2004_350z
South East Marketplace
10-04-2015 12:53 PM
416blueZ
09-29-2015 03:57 PM
Tochigi_236
09-27-2015 03:40 PM
Quick Reply: HOW TO: Rotate Staggered Directional Tires...
