DIY 350Z Track, Rotor and Pad Install, and System Bleed.
Old 01-27-2008, 08:42 PM
Grommit
Grommit's Avatar
Thanks for the write up. Looking forward to doing this myself.
What happened to the pics?
Old 02-14-2008, 08:48 PM
SponGer
SponGer's Avatar
subsciribing
Old 03-10-2008, 05:18 PM
rrmedicx
rrmedicx's Avatar
Any body have a motive pressure bleeder in the tri-state I can borrow? Otherwise, I guess I'll buy one from Z1 Performance. They are pretty close by...in Long Island. I wish I could make the trip in the Z, I could use the mileage.
Old 03-11-2008, 03:32 PM
sugarspunZ
sugarspunZ's Avatar
i will sell you mine. i dont need it anymore. pm me
Old 03-11-2008, 03:47 PM
rrmedicx
rrmedicx's Avatar
I already got a hold of one. But Eagletanggreen may want it.
Old 06-23-2008, 06:04 AM
Barzten1
Barzten1's Avatar
thanks Sug!
Old 06-24-2008, 07:01 AM
donricouga
donricouga's Avatar
I'm going to buy the power bleeder from amazon though i don't know which one? Help me get one.
http://www.amazon.com/s/ref=nb_ss_gw...leeder&x=0&y=0
Would it be better to bleed or replace the fluid. How many pints of brake fluid do i need to bleed and how many should i use to replace?
Also, how can I tell if my rotors need to be replaced. My car has 32,000 miles on it and i don't drive it hard or track it. Should I simply resurface it ?
Thanks
Old 06-24-2008, 02:49 PM
Skrilla
Skrilla's Avatar
I wanted to add in some additional info, this is a great write up, BUT always start with the brake furthest from the master cylinder, this goes for every car. You have a better ability to change the most spent fluid
Old 06-24-2008, 08:03 PM
gr8scott_o
gr8scott_o's Avatar
Great write-up, and helped me a lot.
Two lessons learned. On the first caliper, I had the toughest time getting the bolts lined up when the rotor was loose. I took two of my lugs nuts and screwed them on to hold the rotor onto the hat, it just made lining up the caliper and everything else much easier.
Second, because it wasn't mentioned in this write-up, you do bleed both sides of the caliper. I did outside first, but some say Brembo says to do the inside first. A few love-taps from the rubber mallet to dislodge any air bubbles, and the little Mrs. to pump for me, and all was good with the world.
Old 07-08-2008, 06:33 AM
thekinn
thekinn's Avatar
Amazingly, I did all my rotors and pads a couple weekends ago. I'm new to wrenching on my car - so I was pretty intimidated, but, did it anyways.
The rear rotors were very stubborn. Juice them good with WD-40 or whatever and LET IT SOAK in for 30mins. That's much easier than beating on it for that 30mins+. I did try loosening the parking brake with the screwdriver the the hole trick - that might have helped but I still had to let the WD-40 soak in to the studs and hub to pop those rears off.
Old 07-15-2008, 05:52 AM
jbudnick504
jbudnick504's Avatar
+1 Nice write up
Old 07-15-2008, 07:07 AM
03redlinetrack
03redlinetrack's Avatar
Nice write-up... will come in handy when I replace my front and rear pads. Do you have any suggestions or tips for me?
Old 08-05-2008, 03:50 PM
35Z
35Z's Avatar
Default Brake Service
A good idea is to check the lug bolts for galling (i.e.threads worn) while you are changing out the rotors. Since you are removing most of the items in the way; the stud bolts are inexpensive part to change. Nissan has stud bolts and Nismo has longer stud bolts if your are adding wheel spacers. The last I check the Nissan stud bolts are approx. $2 each. Most of the brake parts (i.e calipers/rotors well have to be removed should one has to change out the stud bolts.
Old 08-30-2008, 12:00 PM
specialized5223
specialized5223's Avatar
Originally Posted by sugarspunZ
When bleeding your brake system you want to start with the wheel that is furthest away from
the driver. Bleed in the following order.
Right Rear
Left Rear
Right Front
Left Front
WRONGO! I followed this advice after I installed SS Brake Lines, Pads, and Rotors. Ended up going to brake masters when I couldn't figure out why the frank my **** wasn't working. The way our ABS it's nolonger furthest from the Master Cylinder to closest. I forget the new order but this is just a heads up. I have an '04 Z too...
Old 11-02-2008, 12:43 PM
VQdriver
VQdriver's Avatar
i'm having a b*tch of a time removing the lower 19mm bolt holding on the rear caliper. there simply isn't too much room to work the wrench and breaker bar. anyone have any tricks? i might try a 19mm open wrench. i hate not having the correct tools.
Old 11-02-2008, 12:52 PM
RandomHer0
RandomHer0's Avatar
^^ I think in the past I've slipped a box wrench over the ratchet end to give myself some more leverage.
Old 11-04-2008, 06:32 AM
VQdriver
VQdriver's Avatar
yea, my problem was i wasn't sure i could use my ratchet because the suspension arm was in the way. i wanted to avoid using my box wrench on that heavily torqued bolt. after a few google searches i found www.infinitihelp.com and they had a rear brake AND bleed DIY. thank God. i simply used an extension and i was able to use my extra long 1/2drive breaker bar and 19mm socket. i found the bleeding instructional to be extremely helpful as well.
for anyone looking for an inexpensive DIY stock brake replacement i used slotted only rotors and axxis/PBR ultimate pads from 88rotors ($280), gruppe-s SS lines ($99), valvoline synth dot3-4 fluid ($7). i had to spray paint the rotors in high temp gloss black for a rust resistant finish. this is my $0.02. hopefully it saves someone the $1,000+ stealership cost.
Old 01-25-2009, 02:16 PM
  #38
lbz
lbz's Avatar
Just did my rears. For the 19mm bolts holding the calipers on I used a wratcheting closed wrench and a 5 pound cast iron dumbell. My hammer wasn't heavy enough. I found a piece of rubber foam to wrap around the wrench so I could put pressure on the other end of the wrench with my hand.
The ratcheting wrench was a good fit, makes the most of the limited space.
On my Motive Power Bleeder, I used the universal adpater. Held the pressure at 10 PSI. I would pump it up to 15 when I started each one, it would go down to 10 slowly and stay put. I didnt want to monkey around with the fitment of the adapter and was making progress so I just left it.
I ended up bleeding the entire system. I put 2 qts of brake fluid in the power bleeder to start. I figure the extra time it would take was worth it.
Motive sells sport drink style bottles with about 12" of hose and a thin braided steel lanyard for hanging off the suspension. Very handy.
Old 03-02-2009, 12:25 PM
  #39
zettahertz
zettahertz's Avatar
Is there an inner and outer bleeding valve on the calipers?
edit: nvm. found a pic and there is an inner valve. I assume bleed inner then outer based on posts I've read.
Old 03-04-2009, 09:35 AM
  #40
guitman32
guitman32's Avatar
REAR ROTOR REMOVAL:
Your bit about hammering the rear rotors off (and the other comment about soaking in WD40 or PB Blaster) are incorrect. No need for hammering or any brute force at all:
You can use this to append your DIY:
https://my350z.com/forum/autocross-r...ml#post3173770
"You need to loosen the parking brake shoes. There is a little rubber plug on your rotor. Align this plug so it is at 11 or 12 o'clock. Then remove the plug. Now, with a flathead screwdriver, you need to turn the adjuster to loosen the parking brake shoes. If you do this, the rotor will come off freely just as the fronts. I see too many threads of people pounding away, when that is totally unnecessary and probably damages your parking brake system and rotors. The FSM is your friend:
Once you have replaced your rotor or completed whatever work you are doing, you need to re-adjust the parking brake. From the FSM:
I thought I would add that it takes quite a few turns to loosen the rotor, so just keep at it!! Also, a flashlight helps in locating the adjuster if you have never adjusted it before...no pounding necessary!!"
Quick Reply: DIY 350Z Track, Rotor and Pad Install, and System Bleed.
