DIY - Solid Subframe Bushing Install - Sikky Manf bushings
Old 01-19-2011, 04:21 AM
ian99rt
ian99rt's Avatar
Originally Posted by JasonZ-YA
For us, it took 3 hours....mainly because removing the old bushings was a little bit of a learning curve.........dropping the subframe, etc was easy stuff, that ive done before, we had that out quick...
if i had to do it again, we could do it fast! 1.5 hours i would bet..
spl only makes solid diff bushings, haven't seen subframe bushings from them yet.....you may be getting confused with what im installing compared to solid diff bushigns as shown by me in this DIY:
https://my350z.com/forum/engine-driv...?highlight=spl
for us the first time yes.....we just drilled holes into it, THEN forced the saw saw blade through and cut out the center, from there once the center is out, its as easy as the rest of them........
Next time we do this, im using the drill saw bits for the fronts.......we will have the oem bushings out in 20 minutes tops for sure now that we know what to do!
-J
Jason,
When you say a "drill saw bit" I'm gathering you mean a hole saw?
Old 01-19-2011, 04:26 AM
JasonZ-YA
JasonZ-YA's Avatar
Originally Posted by ian99rt
Jason,
NO, i mean the drill saw bit I linked in post #4
This one:
Not needed, but I highly recommend Drill saw bits:
Harbor Freight Item #42804 $6.99
If you notice, those SAW DRILL BITS are designed to where most of the shank of the drill bit is used to sorta "ROUTER or WALK" around using a drill........
You can drill into the bushing, then "WALK" the bit all the way around, slicing sideways! This bit would do wonders on the FRONT bushing where we had to drill a few holes into it, just to pass the saw-saw blade..
It's not "needed" but i plan to have them for when we do ACIDJAKE75's car...
I hope to take tons more pics next time...
-J
Old 01-19-2011, 04:28 AM
RandomHer0
RandomHer0's Avatar
Check post #4, those are the bits hes talking about.
Good Job J.
One thing I do is mark the drive shaft at the flanges, this way it goes back in the same way it came out. If not, you may get vibration.
Old 01-19-2011, 04:34 AM
JasonZ-YA
JasonZ-YA's Avatar
^ yes good point....sorry i forgot to add that....I have an "ARROW" marked on my drive shaft to the paint mark on my pinion flange...........
You don't NEED to remove the drive shaft, but it makes it easy to get it out of the way...
the Drive shaft is Carbon fiber, so if you leave it in the car, ensure you protect it with a
towel as it hangs....not like the pic in post #5 where the guy is cutting the bushings out.
Use a towel like this:
Remember, the W-brace is coming out, so just protect it from damage..
Driveshaft orientation and marking:
Drive shaft/ "propeller shaft" LOL...Torque specs:
Nuts and Bolts are 'supposed' to be R&R after every use...i never have,but I constantly check....my car is a track car, I am always checking things before and after...
-J
Attached Thumbnails DIY - Solid Subframe Bushing Install - Sikky Manf bushings-drive-shaft.jpg   DIY - Solid Subframe Bushing Install - Sikky Manf bushings-driveshaft-bolts2.jpg   DIY - Solid Subframe Bushing Install - Sikky Manf bushings-driveshaft-bolts3.jpg
Old 01-19-2011, 09:56 AM
JasonZ-YA
JasonZ-YA's Avatar
As for disconnecting the Ebrake cables...........via PM terrasmack pointed out to me another easy way! ill let him chime in..
-J
Old 01-19-2011, 06:32 PM
AcidJake75
Living in 350Z
AcidJake75's Avatar
-J
PIC for reference..
Old 01-20-2011, 04:05 AM
JasonZ-YA
JasonZ-YA's Avatar
Originally Posted by AcidJake75
PIC for reference..
Since Terrasmack hasnt gotten back, ill post up what he recommended....
^ yes, just like that......Terrasmack pointed out to me that its much easier to simply remove the two pair of nuts with brackets holding the ebrake cable then simply disconnecting it from the rocker -- shown in acidjake's pic.
Like this:
ebrakecableremoval2-1.jpg?t=1295529692
-J
Old 01-20-2011, 04:23 AM
RandomHer0
RandomHer0's Avatar
Makes sense, then just leave everything attached at the brakes? Pull subframe with cables attached and ziptie them out of the way?
Old 01-20-2011, 04:40 AM
JasonZ-YA
JasonZ-YA's Avatar
^ yep, just drag them along as you lower the sub frame and roll it out the back..........
like this:
like when Will Smith is drag'n that moody alien across the desert in the movie "Independence Day"......ya know, the alien he punches? the one that mind fks the president and they shoot his azz up...."peace....no peace" smart mouthed alien..........
LoL....
-J
thanks acidjake for the pics!!! lol....
Old 01-20-2011, 04:46 AM
RandomHer0
RandomHer0's Avatar
lol you're hilarious.
Old 01-20-2011, 04:59 AM
JasonZ-YA
JasonZ-YA's Avatar
Old 01-23-2011, 09:36 AM
exarmyguy
exarmyguy's Avatar
Any driving reviews with the new bushings?
Old 01-24-2011, 10:47 AM
AcidJake75
Living in 350Z
AcidJake75's Avatar
wooooot!!! just got mine today...will get lots of pics of the install..
Old 01-25-2011, 04:13 AM
JasonZ-YA
JasonZ-YA's Avatar
sorry no....I drove it literally around the block only and felt great, but having had the chance to drive around yet to comment well.
cars a track only car and i rarely drive it otherwise, but i will and post up when i do...
-J
Old 01-27-2011, 09:44 AM
JasonZ-YA
JasonZ-YA's Avatar
1st time out driving characteristics:
Okay, so I drove to Whataburger......lol....
Before i begin:
I'll be the first to say that NOISES in general do not bother me one bit. My car has a nismo diff, solid diff bushings, nearly all bushings replaced, spl front upper arms, coilovers and single custom exhaust with HFcats...so my car is loud as it is...
To begin, on the highway the car was great, no unknown vibrations or anything to comment on....
at idiol I did hear some driveline noise, but its hard for me to attribute it to solely the subframe bushings.....
I would hate to say it but this review is premature........ill do more driving when i can...I only Track the car, so ill try and find time to take it out on a few trips, etc...
-J
Old 01-27-2011, 10:10 AM
RandomHer0
RandomHer0's Avatar
I'd have to assume that if someone was going as far as replacing sub-frame bushings with solid ones. They should have little concern for noise/vibration.
I'd rather know how the car handles/performs.
Time will tell once you hit the track.
Old 01-27-2011, 10:19 AM
JasonZ-YA
JasonZ-YA's Avatar
^ Exactly!!!
The car drove and handled well.........it felt just as normal as my car would.....test i want to do are launches and drifts, but i suspect those to feel better....to me the car is very predictable and handles as I expect it too.....
-J
Old 01-27-2011, 10:30 AM
  #38
RandomHer0
RandomHer0's Avatar
To be expected, no bushing "mushiness"
Old 01-28-2011, 01:25 PM
  #39
SikkyMFG
Vendor - Former Vendor
SikkyMFG's Avatar
^ Exactly!!!
-J
Great, thanks for the feedback. One of our initial testers on these said the launching improved drastically. He used to get a real bad shudder/wheel hop and our diff and subframe bushings helped a lot. We are interested to see what you find when you get a chance to track it.
Old 01-28-2011, 05:37 PM
  #40
JasonZ-YA
JasonZ-YA's Avatar
No problem...ill be at a drift event feb 12 weekend..
-J
Quick Reply: DIY - Solid Subframe Bushing Install - Sikky Manf bushings
