removing stripped bleeding screw
Old 09-29-2014, 03:16 PM
reserved
reserved's Avatar
Default removing stripped bleeding screw
Was just going to grab the "nipple" with some channel locks (ouch!) and hope I can unscrew it.
Any words of wisdom greatly appreciated!!!
Old 09-29-2014, 03:37 PM
jhc
General & Tech Moderator
jhc's Avatar
Received 2,225 Likes on 1,594 Posts
If there's nothing to get a box wrench on,
Get an "Easy-out" kit from your parts store, Sears, etc- looks like a drill bit but is designed to grab and remove in a counter-clockwise direction. GL!
Old 09-30-2014, 06:14 PM
reserved
reserved's Avatar
Well, came out REALLY easily. I'm thinking it is the threads in the caliper which are stripped
Old 09-30-2014, 06:37 PM
jhc
jhc's Avatar
Doubt it, any designer/machinist knows that you have to use diff strength metals, and one is designed to fail before the other by using harder/softer materials.
Post a pic of your bleeder valve threads, or better yet-
Just swing by your parts store/stealership. These should be a shelf item.
Old 10-01-2014, 03:03 AM
reserved
reserved's Avatar
I guess the caliper is aluminum, so that is the softer metal - and therefore the one that is going to strip first.
Old 10-01-2014, 02:13 PM
reserved
reserved's Avatar
Yep, it is the caliper which is stripped
Old 05-01-2016, 12:51 PM
OohShiny
OohShiny's Avatar
HI OP - any update / luck with this ? I'm currently having an issue with my bleeder valve not stopping bleeding on my left rear caliper. Swapped that bleeder valve with a spare, still the never ending bleeding. So I'm worried I have a stripped caliper now too.
Old 05-02-2016, 11:51 AM
reserved
reserved's Avatar
There is a thread by a member here "N80" in the autocross/road motorsport section which I think you will find helpful
lapham3
10-07-2022 03:15 PM
11-09-2020 10:27 AM
Depravity
10-01-2015 04:49 PM
Quick Reply: removing stripped bleeding screw
