will my car pass smog? in CA
on
i got a blue 350z track model and i just put a 5/6 intake manifold spacer, jet pop charger, and a 1" throttle body spacer... i was wondering it if would pass CA smog testing
Technically, your car will not pass smog as everything is supposed to be stock or CARB certified. Chances are, at least one of your mods is not CARB certified. Smog shops are privately owned as they are businesses and they don't want to break the rules just incase they are audited or investigated by the state. With that being said, most smog shops will turn you away even if you just have the stock air tube but a $5 Kragen cone filter. Everything must be stock.
However, there are some smog shops that are willing to look the other way, some for a price as long as your car is not throwing any codes.
The biggest factor that will block you is if you car is throwing codes and your Check Engine/Service Engine light is on. Unlike other states which are more kickback, not only does your car have to pass the sniffer test in California, the computer on the computer has to check-out fine as well.
Is your car throwing any codes? Is you CEL light on?
situated
Southern California
07-28-2017 11:47 AM
Vigman
11-17-2015 04:34 AM
Subarism
East Canada
09-23-2015 06:09 PM
