Drag NHRA, IDRC, IHRA, NDRA
wheel an tire choose for drag racing with brembo
Old 04-19-2015, 02:04 PM
joshua350z6841
joshua350z6841's Avatar
Default wheel an tire choose for drag racing with brembo
right now i am running 300zx tt 16x8.5 rims in the rear with P295/50R16 (28'' x 11.5'' - 16'' rear an was running a 18x10.5 with a 285 rs3 in the front bad choose. need a safe front. hate the speed wobble. caught the wall yesterday at 120. so want a safe tire for the front.
also anyone that knows a lot about setup. i don't run a rear sway-bar because of autocross. will that be part of my problem.
joshua350z6841
Default Rear
rear that iam running http://www.jegs.com/i/Mickey-Thompso...rentProductId=
Old 04-19-2015, 02:06 PM
joshua350z6841
Default front
http://www.jegs.com/i/Hoosier/522/18...oductId=746887
http://www.jegs.com/i/Moroso/710/170...oductId=746897
http://www.jegs.com/i/Phoenix-Drag-T...89#moreDetails
Old 04-19-2015, 02:29 PM
joshua350z6841
Old 04-19-2015, 02:30 PM
joshua350z6841
Old 04-20-2015, 07:44 PM
joshua350z6841
bump anyone
Old 04-25-2015, 11:14 PM
OldManZ350
OldManZ350's Avatar
With out the Sway Bar up front, you will get the car drifting left to right at high speed.
But also sounds like you may have something is out of wack with you setup.
Also, for the 1/4 drag strip it's best not to mix Radials and Bias Tires, some cars work ok mixing but not all.....
More info about you car?, setup? daily Driver? Drag Car?
How long have you been drag racing? Runs on car?
Old 04-26-2015, 06:15 AM
joshua350z6841
.... i dont have the rear sway bar on. took it of for autox. will be putting it back on.
......yes i just ordered to 17in stock spare rims to put drag tires on the front.
.....no its not daily driven. might see 2k a year. i use it for every thing. autox track days an drag. Current:
Front..
Camber: -3.1
Toe: 0 out right now will be changing this to. 1/16 out soon.
Caster: 9.3
Rear:
Camber: -2.0
Toe: 0 toe in
link with info on my build.
https://my350z.com/forum/media-share...ild-gtm-4.html
3 runs on the track very twitch handling. even cruising on the streets.
Old 04-26-2015, 06:47 AM
OldManZ350
OldManZ350's Avatar
At what point did the drivability go out the door? Before or After you modified the Suspension?
Make sure you get a Radial Front Tires.
After you reinstall rear sway bar and test drive, report back.
I see in your thread that you have totally redone your suspension. IMO, If the car does not drive right after reinstalling the rear sway bar, you have likely screwed something up.
Old 04-26-2015, 11:43 AM
joshua350z6841
It was fine after I model the suspension. It went to hell when I put more camber in the front for when I run the a6 hoosiers. An then with the et streets it just worthless. Will get more information once I make some changes one at a time
Old 04-26-2015, 01:05 PM
RUNWDVL
RUNWDVL's Avatar
Da hell you do to your enkei?!?
Old 04-27-2015, 01:51 PM
joshua350z6841
curbed it. will be a decoration now.
Old 04-27-2015, 02:50 PM
RUNWDVL
RUNWDVL's Avatar
Your end table? So what are you looking at?
Old 04-28-2015, 12:06 PM
joshua350z6841
i have seen them used for ceiling lights. figured it would look good in the shop.
Old 04-28-2015, 12:28 PM
iideadeyeii
iideadeyeii's Avatar
Throw some jbweld on it
Old 04-28-2015, 06:00 PM
joshua350z6841
i will in time if i get hooked on 1/4 mile times. money is tight right now with getting married an buying a house with in the month lol.
Old 05-01-2015, 05:32 PM
joshua350z6841
OK i re installed the rear sway-bar an adjusted the camber back to -1 an it handles so much better. will update with any changes.
350Z_Al
10-29-2020 07:44 PM
ablaine
11-29-2016 10:13 AM
10-04-2015 07:55 PM
Quick Reply: wheel an tire choose for drag racing with brembo
