Drift SCCA Formula Drift, Drift Showoff, Drift Session, Drift Day, D1 Grand Prix, Drift Nation
Drifting 101 - a guide/insight to drifting the z
Old 04-02-2013, 03:41 PM
  #161
wiringspecial
wiringspecial's Avatar
Does anyone know if you can use the stock master cylinder with an abs delete? I dont mean just an unplug but actually redoing all of the brake lines.
Old 04-04-2013, 12:17 PM
  #162
omgitsweasel
omgitsweasel's Avatar
Originally Posted by VDC_OFF
Anyone have any steering angle solutions for a 370Z?
Edit: Tried PBM spacers for Nissans and they didnt fit.
take a tie rod to a machine shop and just have them make you a spacer that does fit. I have access to a lathe and just made mine, i made mine a little thinner than the ones on the market because i also grip lap my car and was weary of only having 4 threads engaged into the rack on sticky tires. Make sure you use red loctite.
To Jason: thank you so much for this dude. I've been grip lapping my car every chance I could since I got the car a year ago. About 4 months ago I entered in my first drift event and did HORRIBLY. Got on here, read this thread, followed the advice and have been having a BLAST ever since. There is NOTHING like cool-guy drifting in a bright ultra yellow Z with heated seats, navigation open with the orientation arrow spinning all over like crazy when youre sliding, playing japanese **** on full volume on my in-dash DVD player. For good measure, I'll be getting a cell phone windshield mount to record some of this nonsense. Bright LCD screens GALORE! (which also generally looks awesome to the spectators in the elevated stands too)
Now, time to find some more used RE01s!
Old 01-10-2014, 05:48 AM
  #163
Blurvision
Blurvision's Avatar
Has anyone just tried these spacers? Seems like the same idea for 1/4 the price.
"You only need 1 per car. INSTALL ON PASSENGER SIDE."
http://www.enjukuracing.com/products...ck-Spacer.html
Old 01-10-2014, 06:08 AM
  #164
pfregeolle
pfregeolle's Avatar
I have the JIC Magic tie rods installed which have built-in spacers. They definitely work.
I don't know about the "1 per car" thing though...Seems to me like you'd need both sides to be symmetrical in order for them to have equal full-lock.
Old 01-10-2014, 06:30 AM
  #165
Blurvision
Blurvision's Avatar
Yes, you need to re-center the rack.
Found this.
http://forums.nicoclub.com/tie-rod-s...e-t540345.html
Old 06-05-2014, 01:50 PM
  #166
racerizzy
racerizzy's Avatar
i installed the tien tie rods with the spacers and my pass side wheel rubs real bad on my compression arm, drivers side is good. i run a 18x9.75 +20 wheel. any advice would be helpful.i would like to not have to spacer it to much. ive done everything on the list and my car drift like a champ. other than the rubbing
Old 06-05-2014, 01:56 PM
  #167
racerizzy
racerizzy's Avatar
jasonz-ya did you ever do anything to correct the rub
Old 06-05-2014, 03:50 PM
  #168
JasonZ-YA
JasonZ-YA's Avatar
It's your wheel choice - offset, 9.75 inch rim and +20 offset. it is what it is!
Why do you need a wheel that large up front, you turbo z?? need extra grip???
in the end, just replace arms!
the alternatives are expensive kits like the Power by max kit and stuff........and at a point it aint worth it if you can just buy replacement arms for cheap...
pair that arm with the spl compression arm bushing and swap the bushing to every arm you replace down the line...
I'm on arm #3.
-J
Old 12-11-2015, 03:15 PM
  #169
180 drifter
180 drifter's Avatar
Hey everyone. I'm new to the Z33 platform and am hoping to get back into drifting next year. A quick question, and sorry if it has been answered a bunch of times already, will a 18X9.5 +15 rub/lock at full lock. I have seen your suggestions on the first page of cutting the bumpstop and getting tierods but am wondering about wheel sizing. Seems like all the decent knockoff wheels are those sizes is why I am really leaning toward that sizing.
Old 12-11-2015, 03:50 PM
  #170
pfregeolle
pfregeolle's Avatar
I run 18 x 9.5 +20 with a 20mm spacer so effective +0 with 225/40/18 tire size and do not rub.
Should note that I run the JIC Magic inner tie rods with Moon Face Racing Outers. I haven't cut my bump stops on the compression rod yet, but plan to early next year.
Attached Thumbnails Drifting 101 - a guide/insight to drifting the z-12322652_189992018011635_3519751636855916314_o.jpg   Drifting 101 - a guide/insight to drifting the z-12339391_189992054678298_8059903409837815533_o.jpg
Old 12-11-2015, 05:08 PM
  #171
180 drifter
Hey thanks for the quick response. Was the reason for running a 20mm spacer to sit flush with the fender or to clear the arms?
Old 12-14-2015, 06:54 AM
  #172
Fillipe
Fillipe's Avatar
18x9.5+15 with 15mm spacer, 245/40 tire. Didn't rub with tein tie rods. Now with PBM angle kit slight rub on sway bar. LCA and A-arm maxed to -8 camber
Old 01-05-2016, 04:48 PM
  #173
180 drifter
I really thought about buying your car Fillipe. pretty much the end goal for my car but I need something that is a little more daily right now.
Old 01-21-2020, 10:05 AM
  #174
epenbecks
epenbecks's Avatar
Finally found the thread that i'm looking for.
But looks so quiet here. Is there any active drifting thread instead of this one?
Old 01-21-2020, 04:03 PM
  #175
JasonZ-YA
JasonZ-YA's Avatar
Originally Posted by epenbecks
Finally found the thread that i'm looking for.But looks so quiet here. Is there any active drifting thread instead of this one?
Active you say...
Old 01-21-2020, 09:46 PM
  #176
epenbecks
epenbecks's Avatar
yesss... the bos Jason is here
Just watched it yesterday and looks pretty easy. Decided to share here and i'll try on my car soon.
He even has the video that show how to do burnout.
Old 01-27-2020, 12:01 PM
  #177
epenbecks
epenbecks's Avatar
Any one here have experience with fdf mantis angle kit? any reviews on them?
https://www.fdfraceshop.com/collecti...g35-mantis-kit
Trying to get angle kit since i have to replace all the front control arms. But can't afford $2k wisefab
Old 01-27-2020, 12:51 PM
  #178
travlee
Master
travlee's Avatar
Received 9,049 Likes on 6,515 Posts
Acidjake on here used to drift alot and he didnt have angle kit. I feel unless youbare hardcore into it, you dont need it
Old 01-27-2020, 01:25 PM
  #179
epenbecks
epenbecks's Avatar
I don't wanna spend thousands for something i don't need. But since my front control arms messed up and have to replace them, i'm thinking just to replace them with angle kit.
Building my drift car slowly but sure
Old 12-15-2020, 10:05 PM
  #180
epenbecks
epenbecks's Avatar
Just got this FDF mantis angle kit installed Can't wait to drift this thing.
Gage18
10-29-2017 06:20 AM
aaronlosey
Drift
28
09-21-2011 10:12 AM
aaronlosey
Drift
02-08-2010 09:14 AM
350black
Drift
26
12-29-2004 05:27 PM
boma
09-02-2004 04:57 PM
Quick Reply: Drifting 101 - a guide/insight to drifting the z
