Less weight = more power; Have you lightened your Z?
Old 08-25-2013, 12:30 PM
  #761
jerryd87
jerryd87's Avatar
because its not really worth the effort that really isnt a "beast" its roughly 10 or 15 lbs had mine off several times. even the stock k member isnt that heavy nothing like say a third gen camaro where the front k member weighs 100 lbs and you can drop 60 lbs going to a tubular one.
plus fabbing up aluminum structural parts isnt good unless your a OEM, you will find most replacement parts would be DOM tube and heavier then that mostly stamped piece but better stiffness as a result.
Old 08-25-2013, 06:08 PM
  #762
doshoru
doshoru's Avatar
good to know. I've weighed virtually every part I've had out of the car on a hanging scale, and would have visually placed that piece at more than 15lbs.
Old 08-25-2013, 06:58 PM
  #763
jerryd87
jerryd87's Avatar
that particular one probably is due to the extra brace welded in and the extra stitch welds it looks like but they arnt heavy from the factory they are just akward when trying to bolt up.
Old 12-18-2013, 06:58 PM
  #764
KingBaby
Hardest Setting
KingBaby's Avatar
we've seen this picture before....I'm only now joining the party
Old 12-29-2013, 03:29 AM
  #765
iamjustincase
iamjustincase's Avatar
Originally Posted by Gingervitis526
Thats what i was thinking as well, still doesnt make much sense though.
Does anyone know about the 3 "chunks of steel"? I remember reading about one in the trunk but thats about it.
I know there is a chunk of steel attached to the back of transmission roughly 4x4x4 held on with hefty bolts and rubber feet.
IIRC it is for harmonics. These cars have horrible harmonics at certain rpms, around 3k being the worst and that was Nissan's attempt at balancing it I think.
Read a post on here, op claiming he was running car through rpms on a lift and at around 3150rpm, which is where the rasp is bad, he said his entire exhaust system started to vibrate so bad it became blurry to the eye.
So I dunno if its the best thing to remove but it probably weighs at least 1lb.
Btw thanks to the dead thread lover. Never seen this thread before and it was a really good read for the last two days at work. I wanna try some of this on my car, just scared to ruin something so nice.
Old 12-29-2013, 05:03 AM
  #766
350Zdj
350Zdj's Avatar
damn, king baby. wow
How many KGs has that Z lost so far?
Old 12-29-2013, 01:15 PM
  #767
KingBaby
Hardest Setting
KingBaby's Avatar
Originally Posted by KingBaby
1lbs of bolts and brackets
3lbs of sound deadening
13lbs of cubby
still have to clean up a few things
Rough guesstimation is around 2950 +/- at its current state...hopefully still under 300lbs dry without driver when I'm done with the cage!
Love this thread!
Old 12-30-2013, 11:40 AM
  #768
scotts300
scotts300's Avatar
Love this thread!
That should be easy. I have to leave the "cubby" AND be under 3000# (dry no driver) with cage, and I had about 60# of buffer. Get to it!
Old 01-12-2014, 05:57 AM
  #769
warrior07
warrior07's Avatar
Lol.. Just strip everything out of your CAR!! You'll gain so my horse power!!! By now, where do you sit now? Lol
Old 01-12-2014, 10:58 AM
  #770
KingBaby
Hardest Setting
KingBaby's Avatar
I sit in the car....
Old 01-15-2014, 06:16 PM
  #771
Blackheart
Blackheart's Avatar
Very interesting thread, never knew it existed. Been wanting some days just open the hatch and start tearing *hit out.
So for all you that have done this, How much weight do you have to strip off the Z before you noticed a difference in the cars performance? 100lbs? 200?...More?
Old 01-16-2014, 09:27 AM
  #772
scotts300
scotts300's Avatar
Depends if you want something qualitative or quantitative! Get rid of that spare tire in the trunk, and zoooooooooooom the butt-dyno says rawr and fast.
Old 01-16-2014, 09:48 AM
  #773
Z33Garage
Z33Garage's Avatar
How much do YOU weight? I still think that unless you are skinny, the best weight loss to the Z is the weight loss applied to the driver
Old 01-19-2014, 05:07 AM
  #774
Quamen
Quamen's Avatar
True and not true at the same time. My car was 3,150lbs stock with the VQ in it and I got it down to 2,649lbs WET WITH AN LS1 AND TH400 TRANSMISSION. I definitely don't weigh 500lbs so I think it is still worth it.
Old 05-15-2015, 01:50 AM
  #775
KingBaby
Hardest Setting
KingBaby's Avatar
EVAP Box -/+ 10lbs
Miscellaneous metal and exhaust hangar -/+ 3-5lbs
Didn't snap a picture of the full trunk scrap pieces i.e. 10mm studs and remains of the rear cubby were a good 1lbs
Old 05-15-2015, 09:06 PM
  #776
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
@KingBaby = wow, good for you! says the guy with a husky in his profile pic @ 350z tek daut calm...
nugget approves...Name:  null_zpscf95a073.jpg
(talk about weight reduction)
NA&CH (05-25-2016)
Old 05-16-2015, 09:47 AM
  #777
ChriZTT
ChriZTT's Avatar
My contribution to help King Baby keep this epic thread rolling!
KingBaby (06-18-2016)
Old 05-22-2015, 10:22 AM
  #778
boamedt
boamedt's Avatar
Very nice
Old 05-29-2015, 05:03 AM
  #779
snobes
snobes's Avatar
recently weighed my race car so i thought id add it to this thread.
car was 1311kg (2890lbs) with 1/2-3/4 a tank a fuel.
which i was quite happy with since its got a full FIA spec cage and a vortech setup which both add quite a bit.
also still have original doors, hatch and bonnet. etc so still plenty of weight to save.
an interor shot from a few years ago
one from last year
Old 05-29-2015, 05:11 AM
  #780
Row2K
Row2K's Avatar
one from last year
How is the weight distribution with the vortech setup and gutted interior. I imagine its a bit nose heavy and if so have you done anything to shift the weight around; ie.: battery relocation.
Quick Reply: Less weight = more power; Have you lightened your Z?
