Question
Old Aug 28, 2009 | 08:26 PM
jboffill's Avatar
jboffill
Question Question
Hey guys, i hope you all are having a good night. I wanna get this shifter (http://www.shopatron.com/products/pr...61.19261.0.0.0) but i dont know if it will fit on my 07 350Z, or how to install it. Anyone in here has any experience in this field? I would appreciate any help.
Old Aug 28, 2009 | 08:31 PM
03aeroZ's Avatar
03aeroZ
Email Momo
They might have more info or instructions for install
Old Aug 28, 2009 | 09:34 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Any of the aftermarket ***** that I've had have various-sized inserts and you'd use whichever one fit your shifter. They usually have set screws that hold the **** in place on the shifter.
From the looks of that ****, the bottom is probably a threaded ring. With it out of the way, there's probably three set screws. Those would be tightened down, and then the ring would be slid up and screwed on to the ****. Done.
Example: http://www.abdracing.com/mini/projec...opers03-3.html
Z **** just unscrews. You'll want to isolate the shift handle so that it doesn't rotate when you remove the old one. You could screw up your transmission.
Old Aug 29, 2009 | 04:11 AM
jboffill's Avatar
jboffill
Thank you so much for your input! The thing that im really concern is the leather boot and how to attach it to the new shifter. This is the only thing holding me back from buying this item, (I really like this shifter).
Old Aug 29, 2009 | 05:37 AM
03aeroZ's Avatar
03aeroZ
https://my350z.com/forum/body-interi...ft-****-2.html
Old Aug 29, 2009 | 05:47 AM
Just a suggestion. Put a subject in the subject line like
Squeaking brakes
instead of
Help
Need help immediately
If you don't help right away I will die!
Old Aug 29, 2009 | 07:14 AM
jboffill's Avatar
jboffill
Sure, not a problem. Sorry
Squeaking brakes
instead of
Help
Old Aug 29, 2009 | 04:33 PM
jboffill's Avatar
jboffill
Thank you very much for your help. and thank you all
Old Aug 31, 2009 | 07:54 AM
VO...'s Avatar
VO...
Administrator
Squeaking brakes
instead of
Help
+1.
OP, welcome to the forums. Please start another thread with a title that corresponds to the thread content...
VO
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
