Car dies out when starting after pop charger install
on
To begin with, I searched already and found nothing. I just installed a pop charger today and initially when I started the car with the hood open it started fine.
But every time I start the car with the hood closed, the car starts up fine, revs go up, then they go down, past idle, then down some more and just shuts off. I found that if i turn the car on and give it a little rev then the car will stay on and not shut off and then everything else is fine.
I'm not sure what's going on here. Am I not getting enough air? (I don't think thats the case since I should be getting more air now) or am I leaning out? Anyone have any experience with this problem or know what to do? thanks in advance.
on
Dumb question but I have to ask, did you reconnect the MAF after you were done installing it? It should be a straight forward install. I've done about 8 with no issues like this.
on
I also took off the neg battery terminal before I started the install as well so the ecu SHOULD be reset. I might try unplugging it over night tonight to see if that'll fix it.
The only other mod I have is an injen exhaust.
on
Uninstall it and reinstall the stock intake and see if you're still having the same issue. The install doesn't require anything other than disconnecting from - and the MAF.. That's deff strange. Are you sure the battery is up to snuff?
on
I'm gonna stick with the op not reconnectig the maf correctly. With all the random stuff I've seen on here over the last few years, this wouldn't be a surprise..
on
FWIW i've left my MAF sensor unplugged after a pop charger install, and the car started up and idled fine. The only reason i noticed it was unplugged is because shortly afterwards i got a check engine light. Never had any stumbling or stalling issues though as a result of it.
My guess is a vacume hose, or non-related component got unplugged or disconnected accidently in the process.
on
Close, but its actually a 2003 that I picked up used a few weeks ago. I checked the MAF and I'm sure its on the right way. Just to make sure I took it off and put it back on real snug and I'm still getting the same thing. I tried starting it a few times and only once did it stay on, but just baaarely and it hung in there. The other times it just shut off again.
I disconnected the negative battery terminal again and held down the brakes so any charge left in the system would be gone. I'll check it again in a few hours when I go to Bev Mo to buy some Eye of the Hawk.
If it still doesn't work then I'll go ahead and try reinstalling the oem air box again and try that out tomorrow. I'll keep you guys updated. Thanks for the advice so far guys. I was afraid I was going to be flamed to hell and get smart *** replies like I've been seeing here on this forum in the short time I've been browsing and trying to get to know my car better.
on
If that hose being disconnected did pose a problem, i would probably only do it while driving, or under load.
on
We eat our own here, so don't take it personaly when it happens. It's just a matter of time!
on
Roger that. I just reconnected the battery terminal and took the car out to run some errands, and when I started it up the first time, it worked! But... after going to a few places and starting my car up again, it was doing the same thing.
It seems to only start up fine when the engine has cooled down or is cold. But after running it around a bit, I get the same problem.
I'm going to go ahead and swap out the pop charger and try the oem air box again tomorrow and see if that works. So strange...
on
