What synthetic gear oil should I use???
on
Hi everyone, I recently bought a Cusco LSD tpye RS to install in my z. I am gathering all the stuff in advance to do this swap in the spring when my car will come out of hybernation. I already have a Nismo finned cover, new bearings, and 2 new stub axle seals. I am going to have Frank Hill do the swap aswell as my Nismo suspension and sway install next spring. I asked him if he knew the best oil that I should use and he said he would look into it but I thought in the mean time I would ask you guys for your opinion. I baby this car to a degree! I only put 500 miles or so on it this year. Mostly to and from car shows. So its mostly seeing babied secondary road travel. I stay off highways as much as possible. Cops and rock chips!!!! Anyways, I know that certain oils can cause aggresive clutch wear and cause more noise. So which synthetic oil do you LSD guys use?? Thanks, Robert
Redline or Royal Purple.
See this thread for details on how to change, how much, what to use, mix, etc....
https://my350z.com/forum/engine-driv...ssion-oil.html
