installed new clutch now car wont start :(
Old Jul 24, 2010 | 02:14 PM
pntfrk69's Avatar
pntfrk69
Default installed new clutch now car wont start :(
today i installed a act stage 4 clutch. everything went smoothly and after everything was put pack together the car wouldnt start. i have no idea whats wrong. i have a 03 with a vortech, utec, and larger injectors/fuel pump. starter sounds fine, car has gas, it just doesnt want to turn over. any help would be greatly appreciated, thanks in advance.
-cory
Old Jul 24, 2010 | 03:44 PM
diablox1's Avatar
diablox1
how would you know if the starter sound fine if the car wont turn over for you to hear the starter????
with the little info available in op, i'd say dead/weak battery.
Old Jul 24, 2010 | 06:06 PM
pntfrk69's Avatar
pntfrk69
The battery is fine. The starter is turning over just fine but the engine itself isn't turning over. Its acting like it doesn't have gas, but she has a quarter tank
Old Jul 24, 2010 | 06:09 PM
*Boose*'s Avatar
*Boose*
Did u connect the negative ground?
Old Jul 24, 2010 | 07:31 PM
BristishZ's Avatar
BristishZ
disconnect the crank angle and see if it starts. and is the engine actually turning over? or is it just not starting? you may have something bound up.
Old Jul 24, 2010 | 09:28 PM
ben0878's Avatar
ben0878
Sounds like you might have the the flywheel lined up wrong... Did this before myself, I new right away what I did... I was off on the dowel pin to flywheel location, took it apart reinstalled it in the right location and it fired right up... Just a thought although u might just have a bad sensor...
Old Jul 25, 2010 | 06:18 AM
pntfrk69's Avatar
pntfrk69
yes the battery is connected, thats how the starter is able to work fine. we marked the flywheel before we took it off and lined it up in the correct location, ill check the sensor today though. thanks for the help, any more ideas if this doesnt work?
Old Jul 25, 2010 | 06:20 AM
Wu-Watt's Avatar
Wu-Watt
Ya the fly is installed wrong! You gotta take the tranny out again and reinstall the fly properly.
Old Jul 25, 2010 | 06:42 AM
winchman's Avatar
winchman
"The starter is turning over just fine but the engine itself isn't turning over."
Do you mean: a) the starter motor is turning, but the crankshaft isn't turning?
b) the crankshaft is turning, but the engine won't fire?
Old Jul 25, 2010 | 06:44 AM
cdoxp800's Avatar
cdoxp800
Yepp, flywheel installed wrong
Old Jul 25, 2010 | 07:35 AM
Zazz93's Avatar
Zazz93
I would guess the same as the others, flywheel misaligned. Here is JWT's sensor position check. It allows you to get an idea of whether you're installed correctly by checking the encoder positions. If they all check out look to the crank sensor. If it was banged around it could have been damaged and that is a crucial element in telling the ECU when to fire.
Also consider ACT could have delievered the wrong flywheel and thus wrong encoder, if changed.
File Type: pdf
Old Jul 25, 2010 | 07:39 AM
Zazz93's Avatar
Zazz93
Also, try a code reader. The problem may have triggered a code.
Old Jul 25, 2010 | 03:32 PM
Guilty1s's Avatar
Guilty1s
Flywheel has two possible ways to install. One for RWD (G/Z) and one for FWD(maxima) they have specific ways the line up with the Crank and sensor which controls timing. All you could have damaged or forget to connect that crank sensor which would do the same thing.
Old Jul 25, 2010 | 06:27 PM
BristishZ's Avatar
BristishZ
if you disconnect the sensor the car will start off the cam sensor and if its starts its either a bad sensor or flywheel in wrong. if it still doesnt start then............just take it out again.
Old Jul 26, 2010 | 09:45 AM
pntfrk69's Avatar
pntfrk69
unplugged the sensor and still not starting, looks like im dropping the transmission again thanks for the help guys
Old Jul 26, 2010 | 09:50 AM
JasonZ-YA's Avatar
JasonZ-YA
They are probably right about the fly wheel installed at the wrong location as what you are describing is one of the symptoms......
after reviewing these pics, if you didnt ensure you lined up these pins, then you need to drop the tranny and ensure to install the fly correctly.
Look at these pics....
The back of the flywheel has an "indicator hole/mark" that is supposed to line up with the DOT that is shown in this pic at the 12-O-clock position - its in-between the Torx T-55 hole locations.
-J
Old Jul 26, 2010 | 11:41 AM
pntfrk69's Avatar
pntfrk69
thank you very much, i will deff double check that this week
Old Jul 27, 2010 | 05:04 AM
raycs7's Avatar
raycs7
HELP ALSO!!!!
I started having a similar problem with my 03 track.The car ran fine last week.
Parked it in my driveway, went off for a week.
When I first tried to start, it sounded like the starter was not engaging.
After a short while on the charger, the starter turns over the motor normally but it will not fire.
The battery is brand new.The starter tumbles strong.
One person said I had to reprogram the keys.
The engine is stock with only intake mods. All fuses check out and there is fuel at the rail.
Mileage is 980 original.
Old Jul 27, 2010 | 05:15 AM
JasonZ-YA's Avatar
JasonZ-YA
Originally Posted by raycs7
HELP ALSO!!!!
980 miles on an 03 track???
-J
Old Jul 27, 2010 | 07:41 AM
raycs7's Avatar
raycs7
I have several other Z's that I use.
This was in storage but was running fine until last week.
This is my retirement grocery cart... ready to do duty....but,....
All exterior and interior was changed over to 06 couple years ago.
