People with 260+whp on de motor
Old 08-03-2012, 10:41 PM
Pholicious
Pholicious's Avatar
Default People with 260+whp on de motor
What do you guys have to reach 260+ whp
My goal is 260+ with the following mods:
Bassani TD Exhaust
Injen Long Tube CAI
Motordyne 5/16 Plenum Spacer
Test Pipes (If I can figure out how to get rid of the CEL)
Dyno tuned on 91 Octane
Old 08-03-2012, 11:13 PM
KingBaby
Hardest Setting
KingBaby's Avatar
Easily achievable!
What's the condition of you vehicle?
Old 08-04-2012, 12:00 AM
pro_350z
pro_350z's Avatar
Originally Posted by KingBaby
Easily achievable!
That is very achievable!
Old 08-04-2012, 01:26 AM
NightShade
NightShade's Avatar
I had 252whp on my DE when I had the following:
Plenum spacer
Pop charger
HFC
AAM reflash
I'm sure if you add exhaust it'll put you around 260whp.
Old 08-04-2012, 01:59 AM
Mcutali
Mcutali's Avatar
Cel goes away with defoulers. They back the o2 sensor up a bit so its not directly in the stream of exhaust gases. Cel light will go bye bye. I have a 04 touring with AMS Crank Pulley, Z1 headers, Z1 test pipes, Xo2 Catback,Nismo short ram(Jwt heatshielded)K&N,Motordyne 5/16th, Cosworth phenolic spacer, Mild Port Polish of Upper Lower Plenums Chopped front runners down,TurboXs Utec tuned. 288whp 272tq Dynomite by Land&Sea
Old 08-04-2012, 02:25 AM
e30cabrio
e30cabrio's Avatar
Received 2,578 Likes on 2,037 Posts
271/262 on an 06 revup with everything in my sig minus the stroker.
Old 08-04-2012, 02:32 AM
JCITY
JCITY's Avatar
Pretty easy my man.
I've have:Nismo catback,HFC'S,plenum spacer,popcharger,lightly polished/ported
plenum,Mine's throttle body,Nismo cam kit,TUNE by someone that knows what
they are doing.I'm well over the 260 butt dyno.
In fact,you will not need a cam to get there.
Can't emphasize more the omportance of a tune once you slap all this stuff on your
car.More than likely the initial test on a dyno will show your car running lean.You
have to add more "food" to these components to make e'm all work to their fullest
potential!
Old 08-04-2012, 07:31 AM
03threefiftyz
03threefiftyz's Avatar
A couple of years ago, my car laid down a little over 280whp with bolt-ons (on a dynojet). My motor is down on power now a days. At that power level it ran 108-109mph in the 1/4mi (with good DA's).
Old 08-04-2012, 07:37 AM
2bad240
2bad240's Avatar
I have
longtubes
Kinetix v+
Revup lower
Takeda intake
3" y pipe
3" single exhaust
And I made 252 on stock tune
Old 08-04-2012, 07:44 AM
lowematty
lowematty's Avatar
05. 283/27x tuned by Doug on S&R's dyno. Stock block, Nismo heads, MD y w/ res, s tune cat, unknown high flow cats, UR pulley, 5/16" md spacer, Nismo CAI (conv to ram), pop charger, act street lite fly, NGK iridium plugs
Old 08-04-2012, 07:49 AM
One_Quick_Z
One_Quick_Z's Avatar
I had 251whp on an 5AT with Nismo CAI, Plenum Spacer, Megan Headers,APS Test Pipes and Borla Exhaust with out a tune.
DAN
Old 08-04-2012, 08:00 AM
e30cabrio
e30cabrio's Avatar
Sorry forgot I pared the sig.
Injen Cai, Motordyne MREV2, ART Pipes, 5/16th spacer, XYZ with resonator, TB coolant delete, Jet hotted headers, Agency Power Ti, Quaife with 4.09s UPREV tune.
Old 08-04-2012, 05:01 PM
binder
binder's Avatar
652 hp, simply by adding a 6765 turbo
Old 08-04-2012, 05:10 PM
jerryd87
jerryd87's Avatar
oooo ooooo oooo me too me too 587 hp/601 ft lbs of torque from adding a 6765 turbo too(among many many other things *whistle*) should be about 600 hp too now after more fuel out, too bad the car only revs to 6k till i get a new clutch.
Old 08-04-2012, 05:18 PM
e30cabrio
e30cabrio's Avatar
331/347 simply by spending over a year and 11k+++++ on a fully built stoker. :P
Old 08-04-2012, 08:46 PM
Pholicious
Pholicious's Avatar
Thanks for the input guys just got back from a local dyno day event car put down
241whp / 222wtq all I have is a bassani td exhaust and k&n drop in panel .. so with my injen cai coming tuesday and test pipes I have laying in my garage + a plenum spacer I should be 260+ at the wheels
I just need to work on my driving now my shifting is rather slow so no matter what right now im still slow
Old 08-04-2012, 09:19 PM
binder
binder's Avatar
plus a good tune.
Old 08-20-2012, 08:42 PM
TuckerE36
TuckerE36's Avatar
My 06' completely bone stock with 6MT put down 260.825whp and 237.63wtq. 3rd gear pull on a Mustang Dyno. Has only 58k miles. Guess i got one of the better DE engines lol
Old 08-20-2012, 09:03 PM
KingBaby
Hardest Setting
KingBaby's Avatar
Or a high reading dyno!
Old 08-20-2012, 09:41 PM
TuckerE36
TuckerE36's Avatar
It doesn't read high. Typically most Mustang dynos read low if anything.
Quick Reply: People with 260+whp on de motor
