Need some help
Need some help
Hello everyone this is my first post here and I need some help.
I installed a single turbo set up on my z 2004 track edition, and there was a fuel leak with the return fuel set up well the thing is that leak caused a fire in my engine bay. So now I need a new engine harness and a engine bay harness.
my question is can I use a engine wiring harness from a automatic 350z, for some reason they are way cheaper then a 6 speed harness.
any help would be greatly appeciate.
Will a g35 engine harness work on a z those are cheaper too
its like the engine harness for a z runs 140-250 for a 6speed but for an automatic or g35 they are like 80 bucks idk why the hell there so much cheaper lol
but if the transmission plugs are different I could just re-plug the transmission part
I believe you can use an automatic engine harness actually. The only thing that's different on those is the connectors that wire in for the reverse light and neutral position sensor are 1 big plug instead. You could always wire in those plugs yourself but if it's a track only car, I wouldn't worry too much about it
