Water/Methanol Injection install 350z
Old 07-24-2008, 05:20 AM
jpc350z
jpc350z's Avatar
Originally Posted by frankie945
it does not mater how close to the tb as long as the nozzle is spraying in a funnel pattern 360 degrees spray.It is not like NOS. I gained 21 whp and 12 wtq safely. with this set up highly recommend.
Where the gains achievable simply by the addition of the W/M or is it the result of some retuning, i.e. adding some timing, or A/F changes?
Thanks
Old 07-24-2008, 10:04 AM
frankie945
frankie945's Avatar
Thanks
It lowers intake temp, allows you to run more timing. It is a must for superchargers. With my old procharger setup I got 21whp gain and 12 wtq If you do not advance your timing it is kinda like insurance for FI No detionation or knock. pretty much with a 50/50 mix you turn 93 octane into 109 to 112 octane once sprayed
Old 07-24-2008, 10:06 AM
jpc350z
jpc350z's Avatar
Did you run more timing and if so how by how much would be very informative?
Old 07-24-2008, 11:53 AM
frankie945
frankie945's Avatar
yes I ran more timing really don't know how much. I let the tuner do all that.
Old 07-25-2008, 12:59 PM
athenG
athenG's Avatar
Originally Posted by MI 35th
I am doing a meth kit with my utec as a controller, boost or rpm dependent solenoid.
You are basically just controlling at what RPM and Boost your meth kit will turn on. This is not a true RPM dependent spray were you increase the spray as you go up the rpm with the same boost. I'll be real interested how you were able to control the Pump to spray with just the Utec and without the Meth Controller.
The reason you want to spray close to your TB is because water don't like taking a turn so the smoother it goes in the better.
Old 10-27-2008, 09:51 AM
bikinilust
bikinilust's Avatar
It would be a nice touch if you converted the windshield wiper fluid resevoir into your W/M tank. Who uses their windshield wiper fluid anyways??
Old 07-04-2010, 07:37 AM
g35sedan5at
g35sedan5at's Avatar
alot of the srt-4 guys have converted their windshield wiper fluid tanks into meth tanks.
question...is there any benefit to an N/A owner doing this? kinds like a super safe nitrous alternative? or not really.
Old 07-06-2010, 12:19 PM
sir_vq
sir_vq's Avatar
I was wondering this same thing, anybody got a ansewer or theroy to this....
Question...is there any benefit to an n/a owner doing this? Kinds like a super safe nitrous alternative? Or not really.
Old 01-06-2011, 07:19 PM
Neu Era
Neu Era's Avatar
lol
Old 11-23-2013, 07:41 PM
ogiehooker
ogiehooker's Avatar
Originally Posted by Bumble_Zee
nice write up man, but the 25lbs weight got me laughing... our Z weigh like 2500lbs right?(EDIT: 3200LBS) LOL
it would be nice to get a bigger container huh? I guess we don't have any other space to put the meth/alc kit around the engine bay? hmmm... this will be my upgrade along with a procharger...
bumping an OLD thread but here goes...Here's a nice way to get more weight to the rear AND get a bigger tank...fab it! relocate battery and fab a bigger tank...then powdercoat it all.
Attached Thumbnails Water/Methanol Injection install 350z-trunk-water-methanol-tank-and-battery-area.jpg   Water/Methanol Injection install 350z-20130914_125936.jpg   Water/Methanol Injection install 350z-water-methanol-battery-trunk-box-3.jpg
bcoffee20
11-19-2015 06:39 PM
Quick Reply: Water/Methanol Injection install 350z
