5AT to 6MT Swap INFO, ***, DIY, GUIDE Thread!
#81
Sorry to revive a near six month old thread..
To those of you with the 6MT swap and auto ecu with the u1000 code, does your cruise control work (provided you have cruise)? The only thing I see in this thread referring to cruise control is the NPS, but on this z I get a cruise error causing the "set" light to flash. The NPS is working, confirmed by the idle up when put into gear. If U1000 does in fact prevent cruise from functioning, has anyone successfully turned off the U1000 code with Osiris and regained cruise functionality?
Just for background, this one is a 2005 using the MT EFI harness (engine, trans, and harness all came from a 2005 non revup as well) and auto ecu. Reverse lights do not function; is this the case for others using the MT EFI harness? I'd like to know before I troubleshoot the body harness any deeper. I appreciate any valid information.
Ross
Ross
That being said, I think you'll still need the flash for cruise control. That (from what I understand) is needed for cruise control on a manual w/ auto ecu.
#82
I'll bump it also. Hi guys i'm new here. Owner of a FX35 and infiniti scene forum member Raymond. I was doing some search about this swap and of course found many intell (as in the past with other questions as well) here on this forum. So thought it was time to join. My question is concerning the CD009 tranny belhousing. I was told this wouldn't fit the vq35de. That the housing is bigger and only fits the Rev-Up HR and 370Z engine....? Could anyone confirm this ??
The cd009 comes in a separate version for VQ35HR and VQ35DE engines. That's all I'll tell you as there are tons of posts about those transmissions.
#83
on
INFINITI FX35 RWD F/I
#84
on
So I've got the CD009 tranny and all other needed parts. Waiting on the twin plate clutch but am wondering if anyone tried to tackle the wiring to convert the A/T EFI to fit the M/T speed and reverse sensors. Can't imagine all are running without reverse light right ??
#85
Can anyone tell me if I can rewire the 5at harness on a convertible, or do I need a complete harness from a 6mt convt.? Btw I'm doing a LS/t56 swap..I'm not concerned with cruise, shift lights, or reverse lights but I do want normal convt top operations. Thanks
#87
on
My Swap
I'm performing this swap within the next 1-2 weeks depending on how fast the parts come, here is the parts i'm ordering from CZP:
32010-CD00A Nissan OEM 350Z Manual Transmission 03-06 350Z Z33
45163 B&M Short Shifter 350Z
ZSP3003-DE ZSP Wilwood Clutch Master Cylinder Upgrade 03-06 350Z
L3503-NCF-KTP-04 JWT Clutch / Flywheel Combo VQ35DE Package 04-06 350Z
01 :: L3503-NC000 :: JWT Hi-Perf (Plate/Disc) Clutch 03-06 Z33
01 :: L3503-NF000 :: JWT Flywheel 2003-2006 350Z
01 :: 30537-VP200 :: CZP Upgraded Clutch Pivot Ball 04-06 Z33
01 :: NC-310 :: Technafit Stainless Clutch Line 03-06 350Z Z33
01 :: AT01 :: Nissan Clutch Alignment Tool
32202-09500 Nismo Crankshaft Pilot Bushing - Needle Bearing
3730-A Inland Empire Aluminum Drive Shaft MT 03-08 350Z Z33
46503-CD006 Nissan OEM 350Z Clutch Pedal Assembly
30240-07S00 Nissan OEM Clutch Pressure Plate Washer
30223-JA00A Nissan OEM Clutch Pressure Plate Bolt
12315-8J100 Nissan OEM Flywheel Crank Bolt MT Z33,
30620-CD00B Nissan OEM Clutch Slave Cylinder 05-06 350Z Z33
46531-AB000 Nissan OEM Brake / Clutch Pedal 03-08 350Z Z33
J6936-CF45A Nissan OEM 350Z Center Console Shifter Boot Finisher 06-08 Z33
25290-CF40B Nissan OEM 350Z Hazard Switch 06-08 MT Z33
30501-S0284 Nissan OEM 350Z Clutch Release Sleeve 03-06 Z33 350Z
32879-CD00A Nissan OEM 350Z Shifter Control Lever Spring Z33
16439-V5000 Nissan OEM 350Z Clutch Master Cylinder Reservoir Hose Clamp
08911-1082G Nissan OEM 300ZX Clutch Bracket / Exhaust Mount Nut
46127-Q0100 Nissan OEM 350Z Clutch Master Packing Gasket Z33
30850-CD00A Nissan OEM 350Z Firewall Clutch Line - Master to Coupler - Z33
08911-1062G Nissan OEM 300ZX BatteryRodNut
Secures orifice coupler to firewall
08146-6162G Nissan OEM 350Z Passenger Door Handle Bolt, Upper
Secures the lower firewall clutch line to firewall.
30856-CD000 Nissan OEM 350Z Clutch Master Cylinder Reservoir Fluid Tube Z33
30617-CD00A Nissan OEM 350Z Clutch Master Reservoir Z33
30859-CF00B Nissan OEM 350Z Firewall Clutch Line Orifice Coupler Z33
17562-6P002 Nissan OEM Lower Clutch Line Clip Z33
30851-CF00B Nissan OEM 350Z Lower Firewall Clutch Fluid Line Tube Z33
46271-0L700 Nissan OEM 350Z Upper Firewall Clutch Line Clip Z33
#88
on
Added info
Hi i just did the swap on my 03 350z and i had a few
problems that didn't line up with this thread. So here is what was different.
No.1 pilot bushing
Nobody talks about the automatic torque converter bushing and that the manual
bushing is gonna be a bit bigger in diameter then the inner diameter of the auto
Bushing (it is massive steel and not brass compound).
What i did was sand the bushing down in order to make if fit tight in there.
Some say you gotta take that auto bushing out and then you can put the
Manual bushing in. Im not sure if that is true since it looked like the outer diameter of the auto bushing was way bigger than the manual one.
No.2 flywheel bolts
The auto ones didn't fit on the manual flywheel.
They were way shorter. (Pics attached)
No.3 IPDM Wiring
The wiring in the pics and in the description was different
It was not terminal 53 but terminal 43 and the ipdm looks quite different. The only thing that lined up was the wire color gray/red. (Pics attached)
I hope this helps all the 03 350z folks!
Cheers!
It seems like i can't upload more than one pic at a time. Gonna post them separately.
No.1 pilot bushing
No.2 flywheel bolts
No.3 IPDM Wiring
Cheers!
#92
No.1 pilot bushing
No.2 flywheel bolts
No.3 IPDM Wiring
Cheers!
No.1 pilot bushing
No.2 flywheel bolts
No.3 IPDM Wiring
Cheers!
2: The automatic 'flywheel' is actually a flexplate. Different component, so no they don't interchange. I found that out the same way, but it's a quick call to your nissan dealer or courtasy parts. Cheap
3: Yeah totally different setup.
#93
Soooo I just pulled my motor and transmission to do this swap... It will be easy except...
There is info on how to wire the clutch pedal safety switch, the NPS, but NONE on where to hook up the reverse light switch. Are there wires right there? Did they plug into the 5AT transmission? Thanks
#94
#97
I really want cruise control and don't feel like half azzing this because I'll end up wasting an afternoon for one wire.
Instead of tapping into the Green/orange wire at the ECM for the NSS can you tap in where the AT P/NSS plugged into the harness and connect the MT NSS to two of those? Might save a few feet of wire and time routing them to the tranny.
-Mike
