Cam shaft position sensor
Old 07-21-2014, 12:03 PM
jdr63420
jdr63420's Avatar
Thumbs down Cam shaft position sensor
I am having the same problems that many other have experienced with the cam shaft position sensor and the crank shaft position sensor. Nissan regional and I spoke on the phone because my car doesnt fall in to the VIN numbers associated with the recall but the dealership wants 600$ to replace three sensors. I am planning to do it myself instead, but I was wondering if anyone who has already replaced all three sensors recommended any specific brand of sensor or if I should just get the ones from autozone. Has anyone had any more trouble with the sensors they bought? I feel like nissan should be responsible for the defective part that was put in so many cars, but the regional manager wasn't having it when I tried to convince her. Any recommendations would be appreciated.
symptoms: trouble starting, TCS and SlIP Lights on and my car shut off going down the road..
Old 07-21-2014, 12:52 PM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,292 Likes on 896 Posts
In my limited experience, I had a trouble code that identified the sensor and which bank it was on. Have you actually done the diagnostics to confirm that all three sensors need to be replaced, or is this what the dealership told you? In my case, I was competing at Gateway International in St. Louis and ended up going to an area Infiniti dealer to replace the bank 1 cam position sensor.
After that, the race car ran fine and I was able to compete the following day.
Old 07-21-2014, 04:46 PM
jdr63420
jdr63420's Avatar
I have had the SES code read and I took it to the nissan dealership and they diagnosed it. They said they recommend replacing all three sensors. I have already replaced the cam shaft position sensor less than a year ago though.
Old 07-21-2014, 07:07 PM
samsniss350z
samsniss350z's Avatar
If all three SES codes come up then check all of the three sensors and replace.
04-22-2021 09:42 PM
11-09-2020 10:27 AM
2ndchanceZ
10-26-2015 08:03 PM
Depravity
10-01-2015 04:49 PM
Quick Reply: Cam shaft position sensor
