Brian Crower stage 3 cam. Anyone running one without a tune?
Old 11-06-2016, 07:20 AM
M-train
M-train's Avatar
Default Brian Crower stage 3 cam. Anyone running one without a tune?
I'm looking at buying a set of these cams, and the BC site says that tuning the ECU is required.
I've currently got a set of JWT Stage 2 cams which isn't that far off the specs of the BC cam, and they run fine.
Specs of BC cams
lift.........459"/.459"
duration...272°/272°
JWT cams specs
Lift...........430/.430
Duration....256/256
The rest of the engine is 11:1cr, stock tb, 3" air tube, full length headers, free flow exhaust [no cats].
Old 11-06-2016, 02:38 PM
rustyschopshop
rustyschopshop's Avatar
I would 100% do a tune irregardless of what cams you install. You may very well loose power doing a cam install without a tune but there are too many variables.
Old 11-06-2016, 05:40 PM
jhc
General & Tech Moderator
jhc's Avatar
Received 2,225 Likes on 1,594 Posts
You'd be wasting your time and money w/o the tune. Take it to Z1 Motorsports in Carrolton, GA. Jon will fix you up.
770.838.7777
rustyschopshop (11-06-2016)
Old 11-06-2016, 05:43 PM
HRMoneyPit
HRMoneyPit's Avatar
Why is this a question
Can I turbo my car with big injectors and expect it to run safely?
Old 11-07-2016, 03:46 PM
M-train
M-train's Avatar
Well, my current JWT S2 cams ran fine without any tuning.
I had a cam cap break, which caused one of the cams to break for which I found out today that I will be able to just buy a replacement for the broken S2 cam.
I know to get the most potential from any performance mod , of course, a tune is the way to go.
I didn't explain my question, but what I really wanted to know was if the vehicle would have been driveable with that cam until I could get a tune at some time down the road.
Old 11-07-2016, 03:50 PM
travlee
Master
travlee's Avatar
Received 9,049 Likes on 6,515 Posts
why would you spend the time to put cams in it, if you don't want to finish it off with a tune?
