Sponsored by:
Sponsored by:
How to remove window switch panel piece
Old 01-03-2006, 11:23 AM
billet350
billet350's Avatar
Default How to remove window switch panel piece
hey guys im trying to remove the little panel pieces where the window switches are ( the pieces they offer you to lay CF over them) im trying to get them painted in 2 days and have no idea how to remove them, anyone know how to remove them. I havent tired anything yet because i dont want to break them.
thanks,
Old 01-03-2006, 04:28 PM
billet350
billet350's Avatar
anyone..... its the piece they make a cf overlay for....
where all the switches and locks are on the panel of the doors
thanks
Old 01-03-2006, 06:05 PM
boogiemyke
boogiemyke's Avatar
Driver's side:
There is a little rubber cap at the bottom of the recess that you grab to shut the door on the driver's side. Remove it with a little flat-head screw driver to reveal a phillips screw. Take that screw out. Then you just need to pull up on that whole piece. It'll pop out.
Passenger side:
You'll need to remove the aluminum plate on the vertical handle. Do this very carefully with a small flat-head. It's just snapped in place. After you remove that piece, you'll need to remove 2 phillips (or 10mm) screws at the top and bottom of that piece. Then pull the whole handle out of the door. That will give you room to remove the passenger side window switch panel the same way as the driver's side.
You will, of course, need to disconnect the connectors from the switch panels once you've lifted them out of thier place.
Hope that helped and didn't just make it more confusing.
Old 01-04-2006, 05:49 AM
billet350
billet350's Avatar
you are my new god. j/k
thanks alot
i was playing around with the passenger one and almost got it out, but that was before i knew there were screws on the handle lol
definity will do this once i get off work
Old 10-26-2014, 11:07 AM
robbysibrahim
robbysibrahim's Avatar
Hey i read the answer but am still confused. My 2006 350z GT has no recesed area. The handle goes all the way through. I looked everywhere for a screw and can't find one. Can anyone advise? Good photos here: https://www.icloud.com/photostream/#...8-6F70B2C13478
Old 10-26-2014, 12:22 PM
Jennifer 2
Jennifer 2's Avatar
Robby, the inside of the doors changed in 06 and the switch panel you are asking about no longer has the hidden screw. The drivers side switch panel has 5 or 6 plastic pawl tabs on the sides and a couple of metal tabs on the ends. To remove use a butter knife or other implement and carefully pry all around the panel, and it will pop off.
Old 10-26-2014, 01:17 PM
robbysibrahim
Thanks Jennifer 2. I was just about to assume it pries off but I hate that feeling when you hear a snap that's louder than it should've been. So this gives me the confidence to do it.
Old 10-27-2014, 09:12 AM
travlee
Master
travlee's Avatar
Received 9,049 Likes on 6,515 Posts
just pull up on the pleather piece right behind it.... it pops it up enough to get your fingers under it
sales@czp
09-23-2019 03:30 PM
3vilbunny
07-18-2017 05:10 PM
Gruppe-S
Body Interior
13
05-16-2016 10:42 PM
Depravity
10-01-2015 04:49 PM
Quick Reply: How to remove window switch panel piece
