Z part weights... with pictures
#121
on
6 disk radio w/ bracket 8lbs
"The bag" sub,amp,sub bracket,door speakers,rear speaker,main amp/bracket 16 lbs
Passanger interior cubby 2.8 lbs
rear speaker section 2.5 lbs
Sub/cubby plastic 5lbs
Long quater panel/drivers door plastic .5 lbsx2(for passanger side)
Everything else(rear drawes,brackets, all the nuts and bolts from the rear seats to strut bar)
#132
More or less (~3035)....E85 is about 6.4lbs per gallon. That said, I've gotten another 18lbs out of the car since then. It is probably closer to 3010 with gas after the new shocks arrive. I'm hoping the car is in the 2900lb range +/- 3lbs with 3 gallons of gas.
Looks pretty stock (and dirty at the time of the pics) in the car:
#135
Weights of exterior body parts?
Tryin to find out what the weights of specific body parts are on the Z to see which would be most helpfull to replace with CF. Has anyone weighed their stock doors or fenders yet? Or know the weight of any CF parts to see what the actual reduction in weight would be per part?
#137
Could someone weigh their stock front/rear bumpers and side panels. Want to see if i shaved anything off when i switched to a body kit but didnt keep the stock parts. Thanks.
