Sponsored by:
Sponsored by:
Z part weights... with pictures
Old 09-02-2016, 02:14 AM
  #161
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
Yeah that 15lbs seems like a conservative estimate, I pulled the wiring harness that had no purpose also it was 1/2 lb and then cleaned up the other sides wiring also... I cant believe they ran a harness from the front to back with nothing plugged into it. And it took some serious brain strain for my dumb *** to figure out how to unhook it...
I dont think my scale Is very accurate for light weights.
rustyschopshop (09-04-2016)
Old 09-04-2016, 07:24 PM
  #162
rustyschopshop
rustyschopshop's Avatar
That looks like the navigation harness that i pulled out last year.
Old 09-08-2016, 04:02 PM
  #163
dboyzalter
dboyzalter's Avatar
I believe thats what that harness was, I guess it wasnt needed because it wasnt hooked to anything.
I just noticed that I have the same scale as op... Dicks sporting goods $10 purchase ftw
Took off the rear tie down hook... About a pount and a half.
Old 09-13-2016, 11:01 PM
  #164
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
(as mentioned by dboyzalter above) my non-branded fiberglass/carbon hatch is right at 22lbs and the glass came in at 15lbs
Glass(bathroom scale):
Glass(fish scale):
Hatch only(bathroom scale):
Hatch only (fish scale):
Old 09-26-2016, 05:59 AM
  #165
dboyzalter
dboyzalter's Avatar
Look who got a better scale...
2.2lbs
Old 02-19-2017, 09:13 PM
  #166
bealljk
bealljk's Avatar
Has anyone weighed the fuel tank?
Old 02-20-2017, 02:16 AM
  #167
dboyzalter
dboyzalter's Avatar
If the G35 tank is the same as the Z tank I can get it but it might take a month or so... Its almost drained but I've run out of fuel containers... It's pretty heavy when its still got gas in it...
Probably not more than 20 lbs guesstimate...
Ac compressor feels like a lot but only a little over 7 lbs
Not needed pully 3.4
Stock manifold 6.8
Brembo front caliper 7.4
Brembo front rotor 20
Old 02-26-2017, 08:44 AM
  #168
bealljk
bealljk's Avatar
for the archive - transmission cross-member, OEM trans mount & weighted bolt - 8lbs
cross member was 5.5lbs
mount 1.5lbs
weighted bolt 1lb
Old 03-09-2017, 03:24 PM
  #169
dboyzalter
dboyzalter's Avatar
Random weight on side of transmission
Old 02-23-2018, 09:51 PM
  #170
bealljk
bealljk's Avatar
In conjunction with post #122 on page 3 (of this thread).
Passenger side window glass 10.4lbs
Passenger side window regulator - 5.0lbs
Passenger side plate (verifying post #122) 4.5lbs
+/- 20lbs per side
Old 05-04-2018, 11:39 PM
  #171
bealljk
bealljk's Avatar
picked these off the CL ... need a daily driver set of wheels. I believe they are the g37 sport wheels by enkei 18x8 with a 43mm offset (cleared my AP 4piston by about 1/4")
22.71 lbs / 23lbs
Old 10-12-2018, 08:43 PM
  #172
Rick*K
Rick*K's Avatar
I don't remember the total weights but I do remember the difference between the rear hatch OEM and the Siebon dry carbon fiber one is 36 pounds and that in not accounting for that weight they mount to the underside from the factory hatch.
Old 04-18-2020, 10:14 AM
  #173
bealljk
bealljk's Avatar
Seibon's dry carbon hatch (alone) is 15lbs. I added an 1/8" sheet of lexan, wrap, hardware and I'm at 22lbs. The OEM hatch with spoiler, wiper, trim, glass (all in was around 80lbs).
Weight of the gas tank: 39lbs with basket and driver side level gauge
rustyschopshop (04-18-2020)
Old 05-02-2020, 11:08 AM
  #174
bealljk
bealljk's Avatar
Incase anyone is wondering ... the subframe (by itself) is right around 40lbs.
Old 10-19-2020, 10:19 AM
  #175
GodISmE
GodISmE's Avatar
Anyone knows the weigth of the roof? Thinking about making a carbon one.
Old 10-19-2020, 10:28 AM
  #176
iideadeyeii
iideadeyeii's Avatar
A carbon copy of a hood weighs ~1-2lbs more than the factory hood. I'm assuming this would be the same result from the roof panel
Old 10-19-2020, 01:48 PM
  #177
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,292 Likes on 896 Posts
The steel roof is a structural section of the Z33 monocoque. You don't want to remove it without a way to properly bond a replacement section to the chassis.
Old 10-19-2020, 05:52 PM
  #178
bealljk
bealljk's Avatar
I tried closing a roof panel bc I forked mine out and what DK said ... the panel is very very very difficult to cut out ... I had that black parts car z33 and I chopped the entire roof section out and could not cut the panel out ...
but it is indeed crazy heavy bc the structural element of the roof ...
AmorZ_Fati
Mid-Atlantic Marketplace
06-23-2011 03:24 PM
16psibrick
02-04-2010 09:48 AM
16psibrick
Audio Builds
03-09-2009 09:32 AM
16psibrick
Audio Builds
15
11-11-2008 04:51 AM
16psibrick
Audio Builds
55
06-05-2008 08:07 PM
Quick Reply: Z part weights... with pictures
