What are these parts called?
First I want to know what these two parts are called if they even have an official name. In the first picture I'm referring to the black part that is all scratched up. And the second picture, the grey part with the torn "Z".
I want to take off the handle part and sand is down and maybe repaint it black but I cant figure out how to get the damn thing off. And the Z I'm trying to do the same.
I have an 06 350z BTW. Thanks in advance!
Door handle cover and rear strut cover.
For the door handle, pull the handle open and use a small flathead and carefully remove the piece behind it. Once you remove it you should see a screw behind it that holds the cover in place. Be careful not to let it drop in the door or else you will be taking apart the whole door.
On the rear strut cover, you need to pop off the surrounding plastics to remove the silver part. First remove the pieces on the left and right, then front and back.
If you search you will find detailed instructions. Good luck.
Senior Super Moderator
The plastic piece on the door handle assembly is very easy to take out. Like squalz stated, just pull the handle and use a screwdriver to pop that plastic out.
The sub sounds great but I kind of regret putting it there. If I ever need to get to the spare I'm in trouble. Just getting to the jack and other tools is difficult in itself. Amp is mounted in the glove behind the passenger.
I did get the back strut cover thing off and repaint and it looks great!
on
For the door handle cover, I did everything you said and the cover still didn't budge. So I looked up "scratched door handle cover", now that I know what its called , and all the other posts said you have to remove the door panel to get to it. That little black cap under the handle was easy to remove but that's not what I was talking about, I meant the piece that is all scratched up.
Any luck and details on how to remove the scratched plastic finisher around the inside door latch handle? I have a 2006 Roadster and need to both of mine. I could not find the part in the diagram 809 at Courtesy Parts.
Thanks
350Z Project X
Suspension
10-10-2015 09:23 AM
CFAUVEL
10-01-2015 03:20 PM
